Which Type Of Carb Do I Have?
Posted 26 February 2008 - 03:09 PM
the only identifying marks are JZX with 1611 underneath on one side of the float chamber and on the other side there is an f (in itallics with a border round) a 3 and then the number 89 surrounded by a wheel like design. i measured across the throat where it joins the inlet manifold and its 1 3/4" if that helps. there is a tab attached to one of the dashpot screws with FZX1524. The choke appears to have JZX1609 stamped in to it and the throttle has JZX 1605. oh also there is 1127 stamped where the carb bolts to the inlet manifold (4 bolt) and the dash pot cap has LZX 1511 written on it. The carb doesn't look like either the hs2 or hs4 as shown in the haynes manual, float chamber is inline with the dashpot and body for example. Any help gladly appreciated. Cheers
Posted 26 February 2008 - 03:13 PM
look here: http://www.burlen.co.uk
jzx 1605 is the throttle lever part number
FZX1524 is teh part number you need to look for.
Posted 26 February 2008 - 03:18 PM
Posted 26 February 2008 - 03:32 PM
Posted 26 February 2008 - 03:36 PM
Posted 26 February 2008 - 03:39 PM
Posted 26 February 2008 - 04:09 PM
Posted 26 February 2008 - 05:00 PM
The photo of an hif44 i looked at has an oblong face with the bottom two corners cut off.
That is the rear, air filter face of the HIF. You're looking at the opposite sides on the two you are comparing.
Posted 26 February 2008 - 08:13 PM
Your carb was originally fitted to a 1986 1300cc unleaded Metro, its a HIF 44 and originally had a BEJ needleHello, i may well be being dense but i am not sure which carb i have.
