Removing Extension Rod Of The Gearbox
11 replies to this topic
#1 sharon.37
sharon.37
    Starting My Mini Up
  • 3 posts
  • Local Club: central minis
Posted 27 February 2008 - 09:47 AM
Hi, im a newbie so please excuse me but im trying to dismantle a city engine have taken out of the original car with subframe.. now i need to get it off subframe have a haynes manual to help but have come across a problem already trying to remove the extension rod off the gearbox book says" drift out the roll pin securing the collar of the extension housing.." how do you drift it out !!! what on earth is drifting help please... shaz
#2 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 27 February 2008 - 09:51 AM
put the gerabox into reverse, and it moves the pin into the right possition, then use a small punch to drive it out
#3 james105
james105
  • 466 posts
Posted 27 February 2008 - 09:52 AM
On the gear linkage there is a thicker diameter block piece near the gearbox there is a roll pin pushed through, you need to push the pin out to disconnect the gear linkage rods.
hope it helps
Edit: plus what benpopham said, although it might be hard to find reverse if its already out the car.
Edited by james105, 27 February 2008 - 09:54 AM.
#4 sharon.37
sharon.37
    Starting My Mini Up
  • 3 posts
Posted 27 February 2008 - 10:48 AM
thanks will try ... let u know...
#5 Danny-T
Danny-T
  • 111 posts
Posted 11 May 2008 - 02:42 PM
hi, sorry to bring this back up but i'm struggling with this as well (my engine is still in-car). On the thicker part it appears to have 2 'roll pins' but no matter what I do I can't get them out. Do they come out either direction? Is it just brute force I need to employ?
I can get the car in reverse but doesn't seem to make much difference.
Please help!?
#6 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 11 May 2008 - 02:49 PM
Arrgghh!! they are a pain i dreaded putting the new one back in. wich in turn had to be taken out a few times aftrwoods :genius:
I found squirting penatrative grease helps a bit, and maybe close to a whol can of WD-40 cant hurt! :P
Its is just a case of finding a punch the right size, not to small not to big so it wont fit through the hole.
Next thing is the angle. i personally find it easier if the car is in third, or in nuetral with the stick as far over to Off-side as possible.
Its basically a cas of dislodging the rust and Road dirt from inside.
I hope this hlps!!
Alastair
#7 Danny-T
Danny-T
  • 111 posts
Posted 11 May 2008 - 09:48 PM
Arrgghh!! they are a pain i dreaded putting the new one back in. wich in turn had to be taken out a few times aftrwoods :xxx:
I found squirting penatrative grease helps a bit, and maybe close to a whol can of WD-40 cant hurt! :closed:
I hope this hlps!!
Alastair
Thanks Alastair, but ho-hum no luck today though *sigh*, haven't got any punches so was trying with various other things, best fit was a drill-bit and hammer but couldn't get a decent strike on it. Will go and invest in some punches and try again later. Everything else is off and I'm ready to haul out the engine just need to get these damn pins out!
Do I need both of them out or can i just make do with the one nearest the gear box?
Thanks for the tips!
Dan
#8 liirge
liirge
  • 4,097 posts
Posted 11 May 2008 - 09:50 PM
nO JUST ONE, probably the closest to the engine is the best (well either one i always did the one closest to the engine)
Yer, i tried to do that with different things such as nails. but i finally had get a punch that would fit it. i
think there is a punch like tool for vauxhaul brake calipers that fits exactly...but i drift!
Good luck please reply with your news!!
#9 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 11 May 2008 - 09:59 PM
I did it the following way:
1.First off all I sprayed it with a rust spray and let it work over night.
2.3rd gear
3.than use a punch tool ( not too long because the shorter the better it works) than put it on the small opening where the pin roll is in and give it a short hit with a hammer.
I know it is a short, tough job. :closed:
#10 samwell
samwell
  • 1,520 posts
  • Local Club: SC Spammers
Posted 11 May 2008 - 10:27 PM
i gave up after over a week of trying on this. I ended up grinding the gear linkage as i knew i could source another fairly simply.
I believe 3rd gear to make it easier than reverse and in terms of punches, those "watchmaker" screwdrivers with the sivler handles and carbon steel heads do the trick but i was still to weak in the end.
let us know how u get on
sam
#11 liirge
liirge
  • 4,097 posts
Posted 11 May 2008 - 10:45 PM
sam
Urrm, a punch would be better than the Screwdriver, due to equal force around the pin.
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 May 2008 - 06:20 AM
The 'ideal' place for the gear lever is in the reverse gate but not selecting the gear ( so lift and move to the right, but not down into gear )
When you use the correct punch it's easy, and only the ones which have been butchered about because the incorrect tool has been use are difficult to remove with the eventual option being to cut the thing off...
