Hi,
Just bought a new car ('02 astra 1.6sxi) and the only problem (so far) is the passenger interior door handle doesn't work. Anyone know a likely cause of this, and also how to remove the door card without damaging it!?
Or should I just put it into a garage and let them sort it?
Simon
Astra Mk4 Door Card Removal Help Please :)
Neon
, Feb 28 2008 12:09 AM
3 replies to this topic
Posted 28 February 2008 - 12:09 AM
Posted 28 February 2008 - 07:28 AM
iirc, there are screws in the door handle, and a couple round the frame its self. also you will need a trim tool to un-clip the clips holding the door card to the door. not 100% on this as its been a while since i have done one in work!Hi,
Simon
Posted 28 February 2008 - 03:24 PM
Front or rear?
electric window??
If its manual winder you'll need a tool to get the handle off.
Then there various screws hidden behind little caps.
Then pull carefully but sharply and the popperscome out.
electric window??
Posted 28 February 2008 - 04:53 PM
Electric windows. Cheers though, did it this morning and came off relatively easily. And it had a broken window recently and the wire just hadn't been reconnected since then so an easy fix.
