Turbo engine identification
ed4ran
, Apr 18 2005 01:35 PM
18 replies to this topic
Posted 18 April 2005 - 01:35 PM
Im looking at an engine for sale,
and im not quite sure if its an turbo engine,
what should i look for to tell if its a turbo engine?
Ive searched for info on the engine number, and cant find anything about it
(engine number is BHM1300N) the guy says its a remanufactured block,
its not got all the bits with it (its missing the ancillaries so no turbo),
but my plan was to slowly buy the bits and build it up, then when its finished swap it for my current engine.
Posted 18 April 2005 - 01:55 PM
the engine number you have quoted is cetainly not a production engine number, so I would believe the guy who said it's a remanufactured engine.
In general terms, apart from the lower compression ratio ( due to the different pistons ) the engine should be no different from a std metro, but there's something that's niggling me, I'm sure I've heard that the turbo block had some additional oil ways in the casting, but cannot confirm.
Is the gearbox also there, as the turbo had a 3.2 diff as standard, and the head ?
Posted 18 April 2005 - 02:20 PM
It has
Head + rockers + rocker cover
Block
gear box,
flywheel + clutch (but no casing thingy)
So its pretty much a complete engine apart from the bolt on bits
He had it as a spare engine for his Metro
so he hasnt really used it, but he says it turns over fine
And it looks pretty clean condition
What kind of price do you think it is worth?
(i know it would be better to know more about it)
Block
gear box,
Posted 18 April 2005 - 10:49 PM
Is the head fitted? If it's a turbo head the lobe of metal which projects into the chamber between the two valves in a normal head should be very much reduced or missing altogether. Of course if it's fitted then you'll never know....
Posted 18 April 2005 - 10:54 PM
Ive asked to guy to take some more pics,
which he is doing tomos,
and the head is on, but i think the bolts are loose
Posted 19 April 2005 - 07:41 AM
The chamber shape on a standard Turbo motor is no different to the normally aspirated 1275 engines, when the "beak" in the chamber is removed this is in an effort to lower the compression, this is not something done as standard.
To check if it's a Turbo head look at the exhaust valves, they will have noticeably thicker stems than the inlets. If it's a head from a normally aspirated 1275 the inlet/exhaust valve stems will be of the same thickness. The Turbo head also has double springs.
Phil.
Phil.
Posted 21 April 2005 - 08:59 AM
turbo engine numebrs are
something like
12H959aa
something like
12H959aa
Posted 01 June 2005 - 11:46 PM
U sure?? but the thicker exhausrt valves are a dead giveaway! the difference is very noticeable.The Turbo head also has double springs
Bear in mind if it is a remanufactured engine it could have any old pistons in it, if you can, get details of the build.Its not realy worth any more than a normal 1275 unless you can guarantee whats in tehre IMHO.
if you cant hear it running/ atleast see it off the box to inspec tthe bearings its prob worth even less!
Posted 02 June 2005 - 10:27 PM
Yes, all the Turbo engines i've had have double springs fitted.U sure??The Turbo head also has double springs
Phil.
Posted 03 June 2005 - 05:24 PM
Phil.... only the mg metro had double valve springs... the turbo didnt as std. All the turbo engines I have (only 6 or 7) are all singles.
The ONLY sure fire way is to look at the exh valves... the stem is BIGGER than the inlet ones. This is because the exh valves are sodium cooled and have only been used on turbo engines
Alex
Alex
Posted 04 June 2005 - 07:05 PM
Well i've just checked my "stockpile" of Turbo stuff and i have four Turbo cylinder heads, one of which is still fitted to a totally standard and unstripped engine. ALL of them have double valve springs fitted ....
Figure that ! lol :grin:
Posted 04 June 2005 - 08:12 PM
the totally standard turbo head i have is fitted with double valve springs as well, strange....
Posted 05 June 2005 - 12:41 PM
lol I hate you Phil...
Just been out to my shed... its taken me 30 mins to get to my pile of heads...
Only to find the 4 turbo heads I have are all single spings !!!!!
Good old BL!
Alex
Good old BL!
Alex
Posted 05 June 2005 - 11:36 PM
The turbo sat on my drive, and 3 other tuirbo engines iv seen up close and personal were all single spring. hence my post, but i wasnt 100% sure :grin:
Posted 07 June 2005 - 12:34 AM
all the standard ones i've had/seen have been double sprung......dont you just love british made stuff
