Acewell Digidash Help
Posted 08 March 2008 - 11:14 PM
Also on the mini wiring side of things is the green wire with black strip the wire for the petrol gauge?
Cheers for any help
Posted 09 March 2008 - 01:11 AM
Vdd is probably an electrical engineer's way of calling for 12V but the question is... switched or unswitched. Terms like that are routinely applied to the individual chips that go into more complicated circuits. Once you leave the world of Lucas wiring, red is typically used for +12V wires while black is for earth/ground.
Clock power (if it really is powering a clock) will certainly be a permanent live supply. Switch key... without seeing the term in context it's hard to say what they meant. However, I think you're correct that this would be for a power source that's only on when the engine is running.
Posted 09 March 2008 - 10:27 AM
Posted 09 March 2008 - 10:45 AM
got a link to the docs you found online?
Found a Uk site that claims the fuel sensor is 100ohms (switchable on one model).
Edited by Ethel, 09 March 2008 - 10:51 AM.
Posted 09 March 2008 - 02:19 PM
Posted 09 March 2008 - 02:30 PM
http://www.theminifo...x...0fuel&st=15
Edited by Ethel, 09 March 2008 - 03:18 PM.
Posted 09 March 2008 - 02:45 PM
Posted 14 September 2009 - 08:39 PM
Well that sorts that problem out then will wire fuel sender up and see how I go, yeah thats how I was planning on doing the speed sensor but somebody else said that it wasn't ideal so thinking of doing it and seeing how it goes or try something else like gluing a magnet to the pot joint or something.
so dragging up a very dead post what did you do with the vdd? wire
