bike engined mini's
Posted 19 April 2005 - 09:05 PM
Now about the improvements and what I had planned the catagories were;
cheap tax - hence under 1.5 litre
cheap running costs - light as poss, small engine and cheap parts
a 2 person runabout and quick with it...
after some thought I decided a mini, with a bike engine... now before I rush out and buy a mini I need to know some technical details with regard to front axle setup and rear hubs, final drive setup and engine frame. Mounting is an issue too... as is reverse!!!
any info would be appricated, pics would be nice too :cheese:
cheers
Posted 19 April 2005 - 09:11 PM
Posted 19 April 2005 - 09:22 PM
Posted 20 April 2005 - 06:12 PM
their next dvd is building a rear bike engined mini from z-cars
Posted 20 April 2005 - 06:21 PM
Posted 20 April 2005 - 07:09 PM
The front end is effectively mini minus engine and driveshafts. You'll need to think about better brakes (no seriouslyafter some thought I decided a mini, with a bike engine... now before I rush out and buy a mini I need to know some technical details with regard to front axle setup and rear hubs, final drive setup and engine frame. Mounting is an issue too... as is reverse!!!
cheers
You'll get the front coilovers as part of the z-cars kit aswell as the radiator and fuel tank.
The rear axle is all part of the z-cars conversion (basically chain from the bike engine to a sproket driven diff (LSD is an option)
Reverse is also an option in the form of a 5hp starter motor and a large gear.
For pics see any of the projects on here or go to www.z-cars.co.uk
Any more questions your more than welcome to ask (that doesn't guarantee I'll know the answer though :nugget: )
Ade
Posted 21 April 2005 - 10:54 AM
I wanted to build/fabricate the entire project myself... the only bits that I was going to get would be some hosing, the engine (suggestions please, as I know 'busa's and R1's make good donors but what about dukes and the big kwacks, incedentally was about twin 400cc's), the rest I was going to use either the donor biks components or the mini's... hence detailed pics of other frames and actual mounted frames where and how they mount to the shell and where do you re-enforce a mini to cope with big bhp though the rears, and what brake upgrades are suitable for stopping this?
Posted 21 April 2005 - 11:00 AM
Still have a chat with Z-cars though as they have used a lot of other bike engines in the past and are also building a space framed bike engine conversion.
Posted 21 April 2005 - 11:06 AM
Posted 21 April 2005 - 11:30 AM
Ok if you imagine the mini shell turned onto it's roof.explain "space framing" as I have never heard the term
Remove all the floor and build you own chassis complete. You can then choose all you own suspension design and pick up points etc etc.
For a better description have a look at http://www.theminifo...?showtopic=1227
F1 mini is build a bike engined mini on a space frame.
Posted 21 April 2005 - 12:13 PM
