Subframe Alignment?
Posted 12 March 2008 - 08:32 PM
I just don't want to go making holes for brace bars with the subframe in the wrong place.
Thanks,
Adam
Posted 12 March 2008 - 08:35 PM
Posted 12 March 2008 - 08:56 PM
I think once I've done those, i might bolt the subframe up with solid mounts and then use a piece of strong to go from the frount subframe mount to a point on the body, say the bottom of the a-panel and measure on both sides, in theory it should be equal.
Thanks for your suggestion Mini Mad Dan.
I take it there isn't any said play for afjustment in them then, so pretty hard to get wrong?
Edited by Deathrow, 12 March 2008 - 08:57 PM.
Posted 12 March 2008 - 10:22 PM
measure from the bulkhead cross member down to the top front subframe, this will tell if the frame is up or down on each side.
place a straight edge along the front of the subrame and measure from the centre of the rear wheels to the straight edge, this will tell you if the frame is back on each side.
Posted 12 March 2008 - 10:57 PM
Posted 14 March 2008 - 10:30 AM
Solid mounts are a good idea, especially with a flip front. Your Mini should be fine if there's no obvious damage or botchiness evident on the bodywork and suspension. If you still feel the need to check it: park on a flat, level surface and drop a plumb line from some key suspension points, radius arm and lower balljoint grease nipples would do as a minimum, mark their position on your surface; the diagonals should be the same length as should the two front to rear lengths.
Well I'm hoping that by the time I come round to doing this any bad points in the body will have been assessed and sorted by my own hands but as far as i can see, it's all good down there.
My subframe to mounting bolts seem to wiggle around in the subframe bolt holes a little, is this normal or does my car have the wrong size bolts for some reason. Does anyone have any pictures of this area?
Posted 14 March 2008 - 10:41 AM
Posted 14 March 2008 - 01:49 PM
so when a mini has had a accident it is placed on a bodyjig using the same mounting places as the factory jig for the floorpan etc, this ensures that all minis will align up on the jig, any damage will show up as misalignment.
so taking measurments from the same areas that are factory jigged eg, rear subframe mounting points, front subframe mounting point then taking a measurment from the bulkhead crossmember then it will be accurate.
in conclusion, if they are "hand built" then if you place a mini on a body jig then mounting points will not align, but they do because then are hand built but the main parts are jig aligned.
this is my opinion and will differ from others.
plus working in garages for 35+ years jigging hundreds of cars and repairing thousands and working as a coachbuiler building hundreds of bodys and restoring many classic cars from e-type jags, rollers, bentleys, 1920s morris vans and cars etc and repairing hundreds of insurance write off.
