Miss Fire Over 4k Revs
6 replies to this topic
#1 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 13 March 2008 - 07:09 PM
hi, im getting a miss fire once i got over 4k revs, ive re set the timing correctly, cleaned the plugs several times, set the carb properly and its still happening?
what could be causing this, it started not long after fitting my new exhaust manifold.
any ideas?
cheers
#2 munnracing
munnracing
  • 353 posts
Posted 13 March 2008 - 08:47 PM
any ideas?
cheers
Have you checked your points and condenser this could cause a missfire if not set up correctly, this may not help if you have an electronic distributor
#3 insamoufonyx
insamoufonyx
  • 1,633 posts
Posted 13 March 2008 - 11:09 PM
i think its a lecy one, how can i check, i didnt change it but the previous owner may have done?
#4 luke6040
luke6040
  • 449 posts
  • Local Club: na
Posted 13 March 2008 - 11:27 PM
chek theres no holes in the adance tube (tube from manifold to carb) and if not there have been people taking about cleaning off the wieghts and spring in the dizzy this may help.
#5 duncancallum
duncancallum
  • 533 posts
Posted 25 May 2008 - 08:02 AM
is it a diffrent spec manifold as it may be a fueling issue
#6 Broomer
Broomer
  • 1,771 posts
Posted 25 May 2008 - 08:09 AM
pull off the dizzy cap. if you see a big module with two wires going to it its leccy, If you see a silver battery looking like thing, with a peice of metal with two little plates that open and close then its points and condenser.
#7 cap'n crunch
cap'n crunch
  • 1,060 posts
  • Local Club: .
Posted 25 May 2008 - 09:23 AM
yea i would also say it an ignition problem i recently bought a lumentition Magnetronic system, that was faulty and misfiring from 3k upwards.
