Timing Cover Gasket Sealant
7 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 14 March 2008 - 08:11 AM
Hi
When I replace the timing chain and gears, do i put the cover on a dry gasket, or should I use the hylomar non-setting stuff? What type of gasket sealant (if any) should I use?
#2 digitalboy0
digitalboy0
  • 74 posts
Posted 14 March 2008 - 08:41 AM
well working at a motorcycle engineers we always use blue hymitite basicly its a non setting gasket sealent !
does the job brillient just dont go useing loads as it will block ur oil lines just smear it on with ur finger then wipe it off again you only want like 1 mm covering hardly any !
i cannot stress any more about the amount to put on !
#3 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 14 March 2008 - 09:00 AM
I always used to find that cover to be prone to leaking, probably due to its small contact area and small threads on the backing plate so I used to aways use a smear of seting sealant around it.
#4 m1n1
m1n1
  • 769 posts
  • Local Club: I'm unsociable
Posted 14 March 2008 - 10:12 AM
blue non setting gasket joining compound is the way to go. I've been using it for years no problems.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 March 2008 - 10:22 AM
Use Hylomar blue, both sides of the gasket but on the bottom half only. Leave the upper half uncoated. As above just use a thin smear.
#6 mk=john
mk=john
  • 1,167 posts
Posted 15 March 2008 - 07:45 PM
Hi
Thanks for the help. But why should I only coat the bottom half of the gasket with sealant, and not the whole gasket?
#7 jonny d
jonny d
  • 1,148 posts
Posted 16 March 2008 - 01:08 PM
yeah i want to know that aswell
#8 Big_Adam
Big_Adam
  • 7,435 posts
Posted 16 March 2008 - 01:36 PM
The universal force know as GRAVITY has a fair bit to do with it.
Oil will be pulled down ... by gravity. So the bottom of the seal is more likely to leak. Top, not so much.
Still, I used a fine smear all the way round. As it makes life a bit simpler (Hylomar = sticky, good for holding gaskets).
Edited by Big_Adam, 16 March 2008 - 01:38 PM.
