Hmm...horn Isn't Working
4 replies to this topic
#1 Russ528
Russ528
  • 160 posts
Posted 14 March 2008 - 09:37 AM
As per my post yesterday, I thought it was the fuse - but I've put a new one in now and it still not working - although I think the wire that was missing the fuse wasn't actually the horn one, as the wire is just purple, whereas the horn 12v+ is a purple wire with a black stripe.
Is the horn fuse one of the one under the bonnet, or is it lurking in the dashboard area somewhere?
The headlight flasher and everything else is working ok - and I'd be surpirsed if the horn unit itself is knackered as it was a new one fitted late last summer.
Is there an intermediate relay or anything that might be kaputt?
I'm going to have a gander with a multimeter at the weekend, but any other suggestions would be welcome.
#2 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 14 March 2008 - 09:46 AM
Try running a +ive feed straight to the horn to see if its working first
#3 Neilos
Neilos
  • 413 posts
Posted 14 March 2008 - 04:13 PM
good point kel,
thats what i would suggest.
Also check your connections on your horn. If you put a multimeter on your horn connections and push your horn switch on the stalk inside the car, you should see voltage there when the horn switch is pushed. This will eliminate fuses / wiring and point towards your horn / connections being faulty. If you dont see voltage, you have a problem elsewhere.
#4 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 14 March 2008 - 06:09 PM
The horn earths directly to the body of the car - take it off and clean up the area to make sure it is earthing well.
#5 BJst416
BJst416
  • 338 posts
  • Local Club: Racer's Porn Shop
Posted 14 March 2008 - 07:18 PM
Mine was actually grounded to itself, meaning it was grounded to the body of the horn
This caused some problemsin the past, so i took it to a bare metal for ground and problems solved.
