Amplifiers, Need Help!
4 replies to this topic
#1 Lukie-J
Lukie-J
  • 858 posts
  • Local Club: South Devon Mini Club
Posted 19 March 2008 - 06:47 PM
I would like to keep the bootspace and the back seats in my mini so i dont want to take up all the space with subs, so i am wanting to run 4 6x9 speakers (2 on the parcel shelf, 2 under the back seats). unfortunately my CD player cuts out if i turn the volume up (I'm guessin it's because it only has a 4x40 watt output) On the back of the speakers it says up to 300watt.
What sort of spec should i be looking for on the amp, if any!?
Thanks for your help!
#2 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 19 March 2008 - 06:57 PM
Hi, check the earth on your headunit, it sound like you have a bad earth to me.
If you have uprated the head unit the standard one will struggle, remake the connection straight to the body.
Seamus
#3 Rob Himself
Rob Himself
  • 534 posts
Posted 19 March 2008 - 07:57 PM
Your 6x9's saying 300w means bugger all. It's the watts RMS figure that you want..... find this out + we can start looking at amps.
Either your amp is going into protection mode if it has one, or bad earth.
#4 Mini Adam
Mini Adam
  • 682 posts
Posted 19 March 2008 - 08:18 PM
Sourced from www.caraudiodirect.com. Hope this helps:
Why do i need an amplifier?
Adding an amplifier gives you a clean power source that can drive your speakers without straining. That means your music will sound cleaner and more defined at higher volumes. A good quality amplifier will breathe life into your music and hopefully make your journey less of a task.
How much power do I need?
When choosing an amplifier, the RMS rating is the power rating you should pay most attention to. Stereo manufacturers often display peak power ratings on their products. The peak power rating tells you the maximum wattage an amplifier can deliver as a brief burst during a musical peak, like a dramatic drum accent. The RMS figure is much more significant.
The RMS power of an amp is less than half of the peak power. For example, an amplifier rated at 100w (peak) per channel would be about 40w per channel RMS. Big difference, isn't it? Be careful when checking specifications of amps before buying, to see what you are really getting. Always ask for the RMS power of an amplifier.
For mids and highs, anywhere from 30 to 50 watts (RMS) per channel would be a minimum. For subs you would need at least 80 - 150 watts (or more) per subwoofer. There should always be more power going to the subwoofers than the rest of the speakers, since human ears are more sensitive to higher frequencies than lower. For example, if you have 4 x 50 watts going to all your mids and tweeters (total=200 W), then you should have at least 200 W or more going to your subs.
A lot of people wonder if too much amplifier power can burn up the speakers. What damages speakers most of the time is distortion, not power. If the speakers have the proper crossovers and are not distorting, then it is really hard to blow them. A bigger amp just gives you the opportunity to go to higher volumes without distortion. Get the biggest amplifiers you can afford and your car's electrical system can handle. More power means louder sound, but most importantly, cleaner sound.
How many channels do I need?
If you are planning to drive more than one pair of speakers from the amp then you are better off going for a multi-channel amplifier, rather than buying a separate amp for each pair of speakers.
If you plan to drive subwoofers with your amp, choose one with a built-in low-pass crossover which sends only bass notes to your subwoofer.
Remember, if you're driving one sub, you can "bridge" a 2-channel amp to get a significant increase in output. For more information about 'bridging an amp'
#5 Lukie-J
Lukie-J
  • 858 posts
Posted 19 March 2008 - 08:20 PM
Don't even have an amp at the moment!
The speakers say 100 watt RMS with 300 watt peak
Looking for an amp small in size!
