How To Unblock Greese Nipples
Posted 20 March 2008 - 01:10 PM
Posted 20 March 2008 - 01:24 PM
Posted 20 March 2008 - 01:27 PM
Posted 20 March 2008 - 05:23 PM
only a few pence!
Posted 20 March 2008 - 05:27 PM
Or a poke all the way through with a piece of thin welding wire if it needs it.
Posted 20 March 2008 - 06:58 PM
Posted 20 March 2008 - 07:03 PM
Edited by Spenner, 20 March 2008 - 07:10 PM.
Posted 20 March 2008 - 08:15 PM
Unscrew the Nipple, and BOIL it!!
Works a trick!
Posted 20 March 2008 - 08:30 PM
Posted 20 March 2008 - 09:44 PM
Posted 20 March 2008 - 09:45 PM
keep a film of grease over the nipple and it wont happen again......
Posted 20 March 2008 - 10:04 PM
Remove the nipple, poke at the ball sealing the end, hook it to your grease gun and give it a couple of pumps (off the car). Any debris should move right through and NOT get driven into what your greasing.
As mentioned, capping the nipples when not in use is cheap insurance. Over here, Eastwood sells little plastic caps just for that purpose. Before I bought a bag of those, I was in the habit of using the little vinyl hose caps on the nipples to keep them clean.
Posted 20 March 2008 - 10:08 PM
i have some on my brake nipples and there very good at keeping the cack out, the grease coating attracts road grime!
Posted 20 March 2008 - 11:56 PM
Most engineering works will recommend this method.
Posted 20 March 2008 - 11:58 PM
I did find a link that shows what they look like. As luck would have it, this is a U.K. company.
http://www.component...p...egory&id=28
I did find a U.K. manufacturer for covers like these,
http://www.skiffy.com/en/ferrules.htm
(Catalog page at: http://pdf.directind...22944-_146.html )
36 GBP / 1000 pieces. They show offices for several locations in the U.K.
However, you may find any easier, cheaper, and more readily available answer at the DIY center. Go to the section where they sell the enamel (or vinyl) covered metal wire, modular shelving supplies. The shelves are often cut-to-length at the store to fit your needs and vinyl caps are sold in various sizes to cover and protect the cut end of the shelving. I have found uses for these all through the garage. As grease nipple or bleed nipple covers the only problem the vinyl caps have is that they lack a lanyard to keep them attached to the car.
EDIT: by the way, I had lots of fun looking for these things on the net. Go Googling for "nipple covers" or "nipple caps" and see what you come up with.
Edited by dklawson, 21 March 2008 - 01:05 AM.
