A Few Questions.
Posted 21 March 2008 - 10:47 AM
My mini (Austin Mini Mayfair 1985) is due in for an MOT at the end of the month. I know almost certainly that the offside steering gaitor will fail. How easy is it to replace and would i need any other tools than my rather large socket set (considering i am a newbie!!).
Awhile a go i managed to wash the front bonnet badge of because it was onlt stuic on with double sided sticky tape, it was a winged one with union jack on, it was very plasticy. Would anyone know what the orriginal badge would be so i can order both the gaitor and a new badge!.
by the way i saw a pastel blue mini last week at Reading Uni with a Paul Smith badge!!!
Many Thanks
Ant
Guest_iansmini_*
Posted 21 March 2008 - 01:07 PM
linky
and just for fun the price on the paul smith badge
paul smtih
Sorry i couldn't be of any help with the gaitor!
Posted 21 March 2008 - 02:16 PM
Ant
Posted 21 March 2008 - 02:33 PM
Posted 21 March 2008 - 02:44 PM
The gaitor nearest the wheel.
Edited by antdoran, 21 March 2008 - 02:44 PM.
Posted 21 March 2008 - 02:52 PM
The task isn't too hard. Remove the steering rod end from the arm on the wheel hub (using the tool mentioned above). Once it's removed, I advise you to paint mark the point where the jam nut secures the rod end to the rod coming out of the gaiter. Make the paint mark right where the two meet. When you loosen the rod end for removal, as soon as the jam nut moves STOP. Don't ruin your paint mark by continuing to turn the wrench. Hold the steering rod with soft jaw pliers and remove the rod end followed by the jam nut. From there the steps that have to be done to fit the gaiter will be self apparent.
Others will have to comment on what the current preferred lube is for the rack but traditionally you put a quantity of gear oil in the gaiter prior to securing its outboard end with the clamp.
When re-fitting the rod end to the rod, run the jam nut up to your paint mark and stop. Then run the rod end down until it just touches the jam nut. Hold the jam nut in one spanner and the rod end in the other. Tighten them against each other and try to NOT run the jam nut up or down on the rod. Doing it this way insures that you are getting the rod joint back in the position it was originally. If you fail to do this you will need to take the car to a shop to have the alignment checked and adjusted.
Posted 21 March 2008 - 03:24 PM
Posted 21 March 2008 - 08:09 PM
http://www.machinema...l-joint-remover
The link is to a scissor-type ball joint splitter. This is very similar to the one I use. The price looks very good. Still... search for and read the other threads about using this tool.
Posted 28 March 2008 - 08:12 AM
dklawson, when you said gear oil i presume my normal castoral engine oil is the same??
I also got my badge however it has no fixings what do i need?
Thanks,
Ant
Posted 28 March 2008 - 12:23 PM
I have now got the gaitor, wish it came earlyer grrr!!
Thanks,
Ant
There should be three holes in the bonnet with plastic inserts for it to push in to.
My '85 mayfair had a black badge with silver "MINI" and blocks, not the silver and blue, but will all be good.
D
