has anyone done this before
Edited by 998 mini, 21 March 2008 - 05:43 PM.
Posted 21 March 2008 - 05:20 PM
Posted 21 March 2008 - 09:43 PM
The plate that takes the cable has a seal built into it, if there is a leak then the plate will need changing, with a new gasket. Alternative it might just be a gasket leak causing iti think i have a oil leak from where the speedo cable screws in to the speedo drive. is there a oil seal or gasket behind which might need replacing, and am i going to loose all the engine oil if i take it off.
