My List Of Things To Buy, Probably From Minispares
9 replies to this topic
#1 drummerian
drummerian
  • 1,674 posts
Posted 22 March 2008 - 02:35 PM
Body Filler - fill in my crappy welds :thumbsup:
Vinyl Spray - spray my doorcards/dash black
Gasket Set - full set really, is there anywhere they sell sets?...when putting the cv's back into the diff do i need gaskets here?
Oil - Duckhams Q Classic 20/50 oil
Oil filter - GFE443
t1 (or is it g1) rubbing compound
full new carpet set
underseal
WHEEL ARCH R/H REAR GENUINE - minispares are out of these, any ideas
silver paint (for my engine) hammerite?
brake/clutch fluid
engine mounts
ball joint kit (only need a top one, or do you have to get a kit?)
http://www.minispare....aspx?pid=35318 or http://www.minispare....aspx?pid=36102
chrome wing mirrors
chrome locks kit
dash with rev counter (or dials so i can fit my own dash)
added:
bump stop
Edited by drummerian, 29 March 2008 - 03:10 PM.
#2 Jammy
Jammy
  • 25,397 posts
Posted 22 March 2008 - 03:13 PM
First of all, sign up to TMF+, and the discount you'll get at Minispares (7.5%) will probably save you more than the cost of subscribing. Plus you'll get a discount at M Machine, who will probably have the rear arch.
When getting the carpet set, if you can afford it get the Newton Commercial one, they fit very very well, much better than the cheapo sets.
You won't need any gaskets for the inner CVs/output shafts unless you've removed the diff end covers from the casing.
End mounts; don't be tempted to get those poly quick release jobbies. Standard engine mounts are the best. Same with balljoints, go for genuine.
#3 drummerian
drummerian
  • 1,674 posts
Posted 22 March 2008 - 03:16 PM
jammy you ledgend!
thanks for the advice
and tmf + i was going to sign up tonight! been meaning to get around to it and decided this would be my push :thumbsup: the form has given so much to me and i'm happy to give back!!!!
#4 drummerian
drummerian
  • 1,674 posts
Posted 25 March 2008 - 12:16 PM
signed up jammy, just need you to sort out my membership number and stuff now, THANKS!
#5 drummerian
drummerian
  • 1,674 posts
Posted 25 March 2008 - 06:21 PM
ordering soon now =], just waiting on jammy with my membership number
#6 drummerian
drummerian
  • 1,674 posts
Posted 29 March 2008 - 04:30 PM
GSJ166 - SWIVEL PIN KIT GENUINE(does not include grease nipples) 1 £13.36
SO4 - DUCKHAMS PLUS GFE166 FILTER 1 £12.67
21A1902MS - ENGINE MOUNTING MANUAL GEARBOX ONLY 2 £5.10
FAM2764MS - MINISPARES NEW SHAPE POLY BUMP STOP 1976 0N SINGLE BOLT 1 £3.50
AJM804B - GEARBOX GASKET SET(GUG708010TS) 1 £7.41
13H2934 - CLUTCH OIL SEAL UPTO 1992 1 £2.15
ADU5738 - DIFF OUTPUT SHAFT OIL SEAL 2 £1.60
AEC2083 - GASKET 1.5" CARB TO MANIFOLD 1 £0.56
AJM601 - MANIFOLD GASKET INLET/EXHAUST 1 £0.83
GBK1026 - BRAKE PAD CLIPS AND PINS MINI 84 ON EXCEPT VENTED/(LX0033) 1 £3.75
GHF510 - SPLIT PIN FOR GCV1013 3.2MM BY 56MM LONG in GHK1140 kit 2 £0.12
GFK102 - SPLIT PIN FOR MINI CLEVIS PINS (EXCEPT HANDBRAKE) 10 £1.00
about to order these bits, looks good? cheers!
#7 drummerian
drummerian
  • 1,674 posts
Posted 29 March 2008 - 04:43 PM
also, i have stripped a few of the nuts on the rear subframe, any ideas where i can get some new ones?
#8 Kernal H
Kernal H
  • 746 posts
Posted 29 March 2008 - 05:15 PM
If you're changing subframe I'd recommend a subframe fitting kit or similar, has all the essential new bolts and parts. I had to use an angle grinder to get some of mine off so new bushes and mounts were needed.
#9 drummerian
drummerian
  • 1,674 posts
Posted 29 March 2008 - 05:17 PM
the mounts and bushes are fine, but its the nuts that hold the radius arms on (the plates on the end) that i found were a little damaged
#10 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 29 March 2008 - 05:40 PM
the kit has new bolts and nuts to fit the frame.
its still better to replace as its a bugger when they eventually go, the kits only about £15
