Widest 10" Wheels With No Arches?
11 replies to this topic
#1 ferrit
ferrit
  • 716 posts
  • Local Club: n/a
Posted 25 March 2008 - 10:48 AM
I am interested in doing a 12" - 10" conversion on Paddy my retro spi renovation and was wondering what the widest 10" wheel it is possible to fit without needing to fit arches.
Brakes wise currently running standard 8.4" disc set up and I am looking at using the Minispares ( or similar) 7.5" two pot Cooper S conversion. Any other suggestions as to better kits either price or suitabilitywise much appreciated.
Obviously the offset of new 10s will have a bearing and had intended fitting 5" Mambas (possibly problematic with brake set up). Again alternative wheel suggestions appreciated but I was trying to move away from the minilite style of wheel
I was just interested to know if it is actually possible to run anything over 3.5" wide with the Cooper S disk set up without the need for arches.
#2 l_wire
l_wire
  • 180 posts
  • Local Club: MLNI
Posted 25 March 2008 - 11:30 AM
i have cooper s discs. they're great and the 10 inch wheels look perfect on a mini. only problem i hvae is that i dont have a servo so brake pressure is well.....:mrcool:
i think you can get away wih 5 inch wide wheels with no arch. im not entirelty sure. if not 5, 4.5s are fine
#3 ferrit
ferrit
  • 716 posts
  • Local Club: n/a
Posted 25 March 2008 - 11:42 AM
Thanks for that, any chance of a picture?
#4 Jammy
Jammy
  • 25,397 posts
Posted 25 March 2008 - 03:31 PM
I'm pretty sure the 4.5" Reverse rim is the widest you can go with disc brakes suitable for 10" wheels (not 8.4"ers).
#5 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 25 March 2008 - 07:19 PM
i thought the reverse rim sticks out of the arch with discs?
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 March 2008 - 07:23 PM
so did i
#7 redhotmini
redhotmini
  • 1,607 posts
Posted 25 March 2008 - 07:26 PM
i has 4.5 inch minilites, with cooper s discs on one of my minis. if you go for genuine minilites, theres a variety of offsets to suit (ive got a feeling mine were 'S' offset), worth phoning the company to check which type you'll need.
#8 ferrit
ferrit
  • 716 posts
  • Local Club: n/a
Posted 25 March 2008 - 07:43 PM
Thanks guys, I had really wanted to use something other than minilite/minilght so it looks as if i will have to bite the bullet and use arches
#9 Leonard
Leonard
  • 784 posts
Posted 25 March 2008 - 08:13 PM
cooper s steel wheels (LP883) fit within arches, and are 4.5" wide. dont expect them to be less than £200 even for shagged ones on ebay. these fit under the wings
#10 ferrit
ferrit
  • 716 posts
  • Local Club: n/a
Posted 25 March 2008 - 08:20 PM
Cheers Leonard but i couldnt justify putting kosher Cooper S steel wheels on.
Just out of interest this months Miniworld has a "Get it Sorted" article about suspension starting on page 98, there is a yellow mini at the top of the page that has the look i would really like to achieve but looks like its not goinng to happen. Ho hum back to the drawing board Gp 2 or W&P?
#11 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 25 March 2008 - 11:16 PM
Minisport sell Alloy Cooper S rim replicas... their about £250-£300 a set, but worth it.
Minispares do a wheel called "minilife" These are 4.5" wide, and are made to keep the wheel under the arch.
Reverse Rims, have a offset of 1", if fitted with drums, they are level with the body, if fitted with disks, they will stick out 1".
#12 Jammy
Jammy
  • 25,397 posts
Posted 26 March 2008 - 11:53 AM
Ah ok, I was getting Cooper S and reverse rims mixed up then!
