Welder Trouble
7 replies to this topic
#1 bentedder
bentedder
  • 193 posts
Posted 25 March 2008 - 01:13 PM
i went to use my welder today after changing the roll of wire in it last week and the wire doesnt seem to come out the tip very fast at all even when you turn the speed right up. it sounds like the motor is trying to push it really fast but just doenst seem to be making it out the end im using 0.8mm wire and a 0.8mm tip aswell anyone have an idea what this problem is my welder is a siegen 130amp mig.any advice please help
#2 Ethel
  • 25,934 posts
Posted 25 March 2008 - 01:26 PM
http://www.mig-weldi...plex-shapes.htm
Spool mounting or feed roller tension?
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 25 March 2008 - 01:46 PM
I agree with Ethel, but also what are you welding, it won't affect the wire speed, but if its mini bodywork, you will probably get better results with 0.6 wire and tip
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,139 posts
  • Name: Sean
Posted 25 March 2008 - 01:50 PM
Have you tried removing the tip and then trying to feed the wire through?
#5 bentedder
bentedder
  • 193 posts
Posted 25 March 2008 - 01:58 PM
im welding some panels on to my mini i will change my wire and tip to 0.6 and see if there is a difference. when i remove the tip the wire comes out just as slow.
#6 Ethel
  • 25,934 posts
Posted 25 March 2008 - 02:05 PM
Look at the spool and feed wheel. the wire might be crossed under itself and my Mig had a habit of tightening the spool clamp by itself
#7 james105
james105
  • 466 posts
Posted 25 March 2008 - 03:24 PM
Could be a dirty liner, wire caught on spool, not tensioned correct.
If you say it sounds like the motor is turning fast, then to me it sounds like the wheels are gripping the wire enough, try increasing the tension. If its tensioned ok, and its still doing this, then i would suggest that the liner is dirty. How old is the welder/ how much use has it had?
#8 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 25 March 2008 - 03:31 PM
was you using that size wire before you changed if not maybe that the feed reel needs turnng over they usually have two slots one for .6 the other for .8 have you checked to see if the reel spins free before you feed the wire ie new reels not binding up on the spindle its mounted on.
