Dim / Dip
Posted 26 March 2008 - 07:30 PM
We are having difficulty with the lights on our 1992 Mini cooper 1.3i. The side lights work, the dim lights come on when the ignition is running, the main beam works when 'flashed' but we have no dipped beam. The fuses all seem to be ok. Is the Dim / Dip relay the most likely cause of this problem?
Posted 26 March 2008 - 11:36 PM
Posted 27 March 2008 - 07:47 AM
Posted 27 March 2008 - 01:12 PM
Wiring connections at the front of the car behind the grille: -
Earth is the Black wires
Sidelights are Red/Red with Green
Headlights are thick Blue with Red
Main Beam thick Blue with White
Posted 27 March 2008 - 08:18 PM
Failing that check the bullet connectors behind the grille: -
When mine did this, it was the the connections behind the grille that was the problem.
Posted 27 March 2008 - 08:31 PM
Posted 27 March 2008 - 09:30 PM
Posted 28 March 2008 - 01:27 PM
waiting for the new relay so hope that solves it but thanks for all your replies. Hope it's not the stalk because we just fitted a new one! (The indicator swirch jammed)
Will play with the wires and let you know.
Thanks again
Posted 29 March 2008 - 07:55 PM
was it new new or new 2nd hand? changed mine today and all is good with my lights now!Hi.
Thanks again
Posted 29 March 2008 - 09:30 PM
Posted 30 March 2008 - 02:20 AM
Posted 30 March 2008 - 06:24 AM
Quite simply, if the flash works and the main beam don't then it's the stalk, then it's either the +ve feed from the light circuit to the main beam switch which is failed or the switch (stalk) itself...
Posted 01 April 2008 - 08:54 AM
Thanks again
It was new so I'm hoping it's not at fault. Is there an easy way to check?
Posted 27 April 2008 - 03:28 PM
