Engine Stalling
Posted 27 March 2008 - 06:27 PM
ive got a 1997 MPI, with twin DTM exhaust and a pipercross filter/induction kit.
my problem is sometimes when i put my foot down on the clutch the engine stalls.
usally when im on my way to college it doesn't do this but does on the way home.
ive also tried putting the clutch down whilst doing 50mph and the engine stalled again.
i brought it about a month ago and aparently the ignition coil unit and engine steady mounts had been replaced.
has anyone got any ideas what this maybe?
Posted 27 March 2008 - 06:59 PM
When you dip the clutch does the engine slowly die, or is an instant stop as if something is forcibly stopping it? If the clutch is worn then fully depressing the clutch won't completely disengage the engine from the gears, which would put extra load on the engine if you're not giving it some on the go pedal as well - it's like lifting the clutch slightly without bringing the revs up first. Does the engine cut out when you're at a stand-still? In neutral?
Posted 27 March 2008 - 07:19 PM
Posted 27 March 2008 - 11:35 PM
only difference i can possibly think of for there being a difference going too and from college is the car maybe warmer coming back but i travel about 25 miles to and from college so not sure about theat apart from that nothing. when i put my foot down on the clutch the revs just drop, but i have found if i slow the car down in gear untill its judderong about to stall and then put my foot down this can stop it stalling as the engine then speeds back up to normal idle.
Edited by THEMELV, 27 March 2008 - 11:39 PM.
Posted 27 March 2008 - 11:39 PM
Posted 28 March 2008 - 01:44 PM
Fit a new O-ring when you refit it.
Posted 28 March 2008 - 03:48 PM
IACV position is here below the air filter on the left side.
Posted 31 March 2008 - 03:42 PM
Posted 16 April 2008 - 03:38 AM
I think its quite curious that it only happens when engine temp is right near the middle line just slightly above normal.
Posted 29 April 2008 - 04:40 AM
Posted 01 May 2008 - 09:05 PM
I noticed something today as I tried to get it to stall. Once the motor is warmed up to the point just past the white dot on the temp guage, as soon as the fan kicks on I can get it to stall as long as my foot is off the throttle, but once it stalled the temperature reading dropped back down to cold but the fan stayed running. The temp continued to fluctuate between normal and cold the rest of the trip. I disconnected the plug when I got home and cleaned the contacts on both the temp sender and the connector and tomorrow I will try to get it to stall out. When I do my coolant flush I am going to swap out the sensor for a new one and see if my problem goes away.
yeah mine does exactly the same when it stalls the temp drops right off and then takes forever to go back up
Posted 06 May 2008 - 05:10 PM
Turn the ignition key to position 2
Press the accelerator peddle 5 times
Turn off the ignition and wait a minute
Start engine.
If tick over doesn't settle, repeat.
Posted 07 May 2008 - 05:41 AM
After a particularly bad run on the highway with some bad stalling and stuttering, I had an idea. On a hunch, I pulled the plugs out and noticed that the electrode surface was very pitted and not very nice looking. I cleaned them up with some sand paper and regapped them. Driving around today I had no problems whatsoever, so I think it was just an issue with the plugs not firing properly at steady speeds but I dont want to say that it was the problem.
Does that make any sense that there would be a different spark response between acceleration and steady driving?
Posted 07 May 2008 - 10:33 AM
Posted 31 May 2008 - 09:56 AM
i replaced my coolant sensor as it thought this may be the problem after reading a couple of things to see if this would help. it hasn't and still stalls
