My 2lt 16v Redtop
Posted 28 March 2008 - 09:33 PM
Posted 28 March 2008 - 10:17 PM
Posted 28 March 2008 - 10:47 PM
good luck with the build
cheers
Posted 28 March 2008 - 11:14 PM
I want to see some more pics of your conversion looks a good one
Regards
Aaron
Posted 29 March 2008 - 01:36 PM
Wow that Zcars subframe looks impressive, i didn’t know zcars made front subframes for Vauxhall engines!, can I ask what alternator and the ampere of the alternator you are using? im trying to find a small one for my Vauxhall conversion but don’t know which cars have a small alternator.
Regards
Aaron
i think this is the only one that they made and i dont think thay will make anymore
the alternator is from a nissin micra dont know the amps and still trying to mount it
hear are some more pics
Posted 02 April 2008 - 10:11 AM
Posted 02 April 2008 - 11:25 AM
is your engine solid mounted to that zcars frame?
looks like thay have used there standard engine mounting bushes where the engine mounts bolt to the subframe
Posted 02 April 2008 - 12:45 PM
Makes it quite tempting to hack mine to bits and stick a Honda engine in there...
Posted 02 April 2008 - 12:48 PM
Can I ask what you've done with the top subframe mounts? I assume the Z-cars frame uses tower bolts type fixings, where I assume your shell (being a 1971 I assume) would have had a twin bolt type subframe (two bolts per side)???
Posted 02 April 2008 - 01:28 PM
Posted 02 April 2008 - 06:33 PM
Posted 08 April 2008 - 08:13 PM
Posted 08 April 2008 - 10:46 PM
Posted 09 April 2008 - 07:09 PM
Posted 09 April 2008 - 07:24 PM
