Rev Counter Bounce
5 replies to this topic
#1 91COOPER5
91COOPER5
  • 29 posts
Posted 31 March 2008 - 01:43 PM
Can anyone tell me what would cause the rev counter needle to bounce around and read eratically. It seems to read ok at high revs but will bounce around for a bit when the revs drop.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 31 March 2008 - 02:10 PM
Bad coil connection. Check if coil connectors are loose.
If they are just nip them up with some grips. Then put them back on the coil.
#3 stickycreambun
stickycreambun
  • 1,865 posts
Posted 31 March 2008 - 02:17 PM
or maybe bad connection on the tacho, though more likey to be the coil.
#4 91COOPER5
91COOPER5
  • 29 posts
Posted 02 April 2008 - 06:44 AM
Checked both connections. Both are good. I lost the Taco completly this morning, also lost the heater. I'm going to go over the wiring as best as I can tonight. I'd guess the heater has stopped working due to a blown fuse.
#5 Wil_h
Wil_h
  • 3,244 posts
Posted 02 April 2008 - 07:19 AM
Could be the voltage regulator on the back of the dash. but also therse rev counters are not the most relaiable and I have seen many fail in this manner.
#6 91COOPER5
91COOPER5
  • 29 posts
Posted 02 April 2008 - 12:41 PM
Ok, got the tacho and heater working. Replaced all the fuses for new ones. Think I'll look at replacing the fusebox with a new blade Fuse Box.
If it was the tacho that was faulty why would it be getting affected by the stereo or any other electrical equipment.
I'll have a look at getting a new voltage regulator. How is the tacho earthed and where abouts is it so i can check the earth is ok. is it possible to run a wire directly from the coil to the tacho so that I can verify whether the harness cable is getting interference somewhere.
