Hole In Water Pump
9 replies to this topic
#1 jpdub17
jpdub17
    Starting My Mini Up
  • 4 posts
Posted 31 March 2008 - 03:47 PM
does anything go in the hole on the water pump?
it doesn't look threaded on mine but it leaks tons
of fluid. i can't find anything anywhere that even
mentions what this hole is for.
#2 mike.
mike.
  • 6,176 posts
Posted 31 March 2008 - 03:48 PM
Bypass hose or something?
#3 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 31 March 2008 - 03:49 PM
It's there to leak leak water out of the water pump when the seals/bearings have gone...
So you need a new water pump...
#4 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 31 March 2008 - 03:50 PM
I always thought that it was a drain of some sort and if it leaked then you pump was shot as it was leaking water past the bearings.
#5 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Where abouts is the hole?? it could be bypass, i might have jumped in the deepend a bit with my last reply.. lol
#6 jpdub17
jpdub17
    Starting My Mini Up
  • 4 posts
Posted 31 March 2008 - 04:06 PM
Attached File  waterpump1.jpg   13.88K   3 downloadsAttached File  waterpump1.jpg   13.88K   3 downloads
it is a small, about 1/8", hole on the cylinder part of the pump near the fin that leads to the pulley
hopefully this picture helps
#7 BoboGib
BoboGib
    RoboGimp
  • 1,579 posts
  • Local Club: SMAC
Posted 31 March 2008 - 04:08 PM
yeah the little tiny one is as sstated above. Its a drain for water leaking past the bearings. If there is loads coming out then io'm afraid your pump needs changing.
#8 jpdub17
jpdub17
    Starting My Mini Up
  • 4 posts
Posted 31 March 2008 - 04:10 PM
ok thanks
just another opportunity to make the compartment look fresh
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 31 March 2008 - 04:11 PM
You have marked the weep hole. As others stated, it's there to give you an indication when the pump seals have failed. Get a new water pump soon. The bearings won't be long for this world.
SIDEBAR: I had a Honda Accord once where I ignored the small amounts of radiator fluid I found on the garage floor. It turns out they were coming through the weep hole. One Christmas eve I was driving to my in-laws house when the pump seized up. It put such a load on the drivebelt for the fan and alternator that it darn near stalled the engine. Fortunately it broke free and I limped the last 2 miles to their house where I spent the afternoon sourcing and replacing parts. Fix your pump now so you aren't similarly surprised.
#10 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 03 April 2008 - 09:30 PM
I'm having exactly the same problem at the moment, was gonna post up a topic about it!
