How To Id An En40b Crank?
3 replies to this topic
#1 bcmini
bcmini
    Starting My Mini Up
  • 3 posts
  • Local Club: Vancouver Mini Club
Posted 01 April 2008 - 06:10 AM
Hi,
I've been looking at a couple of 1275 S crankshafts for sale that have had their original casting numbers ground off (but are re-stamped EN40B/AEG480).
I was told that they have been balanced, wedged, or polished. So they have no original raised casting numbers - only hand stamped replacement numbers. Is there any way of determining that they are in fact Cooper S EN40B cranks. Anybody can grind off casting numbers and re-stamp as EN40B/AEG480. I am not able to see them in person, only in pictures. I didn't make an offer and lost out to another bidder, and so now I'm wondering (for future reference) if there is a way to ID the real thing. And if anyone knows of one for sale, please send me a contact.
Thanks Joe
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 April 2008 - 06:52 AM
The following casting numbers...
AEG330 EN40B not cross drilled 970cc
AEG171 EN40B not cross drilled 1071cc
AEG315/6 EN40B not cross drilled, nitrided, 1.625" 1275cc
AEG479/480 EN40B cross drilled, nitrided, 1.625" 1275cc
courtesy of Minispares
If they have been ground off then any bodies guess, but if you're after a modified crank then what's so special about a cooper S crank ?
eg a crank which may have started life as a fairly std A+ crank which has been modified to be used in a miglia is going to be a better crank than a std cooper S crank !
Edited by GuessWorks.co.uk, 01 April 2008 - 06:56 AM.
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 01 April 2008 - 12:01 PM
So... what does that mean? What mods are done and what about them makes the crank better?
#4 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 01 April 2008 - 12:03 PM
A miglia spec crank is has had the following work done:
stroked, relieved, wedged, and balanced.
I believe it's favourable to have a 4 bolt steel centre main bearing cap too.
Edited by Retro_10s, 01 April 2008 - 12:03 PM.
