Rite need help agian on the best setup Ive got the following:
Pioneer DEH-P80MP 4x60w 3x6.5v preouts lpf/hpf/crossover/eq
JBl 4ch 4x50rms amp
Alpine 4ch 4x50rms amp
jbl 13cm 45w rms speakers in the front 70-21,000hz [size=18]Staying in![/size]
Phoenix gold 6x9's/blaupunkt 6x9's waiting to see what pg will sound like should be better
Jbl 16.5cm 55rms speakers
Pioneer 10" sub 18-2,500hz
Infinity 12" sub
Im thinking Of using the jbl amp as it's slightly more powerfull when bridged to power both subs and lpf to stop anything over 300hz.
Then the alpine amp to power 2 sets of these: (which not to amp)
Front 13cm jbl's
Back 16.5cm jbl's
PG 6x9's
I know people r going to say you don't need the 6x9's but im going to filter out most the low hz as they give quite good vocals. Ive seen some special speaker pods for the shelf for 6x9's and was thinking would I be better putting them up there and the 16.5cm in a speaker board or viece versa, or only using one set.
1 final Q is it possible to use the hu crossover/filter and internal amp to run sum tweeters in the front.
Any help would be great!
Scarface
, May 03 2005 05:02 PM
1 reply to this topic
Posted 03 May 2005 - 05:02 PM
Posted 03 May 2005 - 10:35 PM
seriously though, dont bother with the 6x9's. the 13's and 16.5's will have more than enough high Hz for your car. are you using both subs? i think the 12inch infinity by itself in an exact sized properly built box would sound awesome!dont run speakers in the shelf if you have a sub in the boot, the air displacement will damage the voice coils in them and eventually completely bugger them
oh from experience id use the alpine amp for which part of the music you like best.
i.e. use it for the sub(s) if you like bass, use it for the co-ax's if you prefer SQ.
im not sure but i dont think you could run tweeters from the HU but im not sure on your standard filters. could possilbly run them through a crossover!
hope this helps
hope this helps
