As the title really...
I want to clean up and de-rust under the wings properly.
I've removed the big air pipe, it's just the moulded plastic air duct left under there now. How do I remove this?
Seems to be held on firmly although I can't see any fixings.
Thanks,
Ed.
Plastic Air Ducts Under Wings...
edi57
, Apr 03 2008 05:56 PM
5 replies to this topic
Posted 03 April 2008 - 05:56 PM
Posted 03 April 2008 - 06:35 PM
four bolts on the upper footwell, you'll have to be in the car to get them if i remember correctly.
Posted 03 April 2008 - 08:18 PM
do you mean the bit inside the engine bay or the pipe under the wheel arch? i presume you mean the black inside bit in which case mine just pulled off but it has a lip all the way round which sits very tightly to the arch and was a struggle to get off! check for fixings before yanking tho!
hope that helps
james
hope that helps
james
Posted 04 April 2008 - 07:28 AM
Picture of the duct I'm trying to remove:
[attachment=55104:03042008151.jpg]
Posted 04 April 2008 - 09:27 AM
As was mentioned previously, the fixings are on the inside of the car. Four nuts secure the duct. Undo them and it should come off without to much grief...!
Posted 04 April 2008 - 10:12 AM
yep sorry i misread ... as he said^^ !
