How Heavy Is An Engine?
12 replies to this topic
#1 james753
james753
  • 219 posts
Posted 04 April 2008 - 10:46 PM
how heavy is the whole engine assembly in kg's? and how many people could lift it? how heavy are the cylinder heads on there own? - would removing the head make a difference?
cheers
James
#2 wayneb911
wayneb911
  • 180 posts
Posted 04 April 2008 - 10:57 PM
Deepends how strong you are! I can lift an engine no problems, the cylinder heads are not that heavy, are you trying to lift it into a car?
#3 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 04 April 2008 - 10:58 PM
Very heavy is the answer.
If you want to lift it out and haven't got a hoist then you can take the head off and clutch plus transfer gear case then unbolt the engine from the box.
It is then possible to lift the engine out.
I used to do it this way when I was a young man but it was a struggle, possible , but a struggle. :thumbsup:
#4 TJenkos
TJenkos
  • 4,815 posts
Posted 04 April 2008 - 11:11 PM
Me and my mate have lifted one using rope and a scaffolding pole. Was a struggle but it worked..
#5 james753
james753
  • 219 posts
Posted 04 April 2008 - 11:12 PM
would two strong young lads be able to life one then?
#6 minipac
minipac
  • 317 posts
Posted 04 April 2008 - 11:17 PM
me and my wife have lifted engines in and out complete but an engine hoist help save trapped fingers when putting them back
#7 stickycreambun
stickycreambun
  • 1,865 posts
I seem to remember they are about 95kg, without fluids. just under 100kg anyway. moving a fully built engine is simple for two strong men, lifting one out of a bay is another matter. I cant see it possible. lifting off a subframe is no problem, but there is not much to hold on to so getting one up and out of an engine bay would be a different story..
If your just moving it you should manage all built up with the head, just make sure what you use is ok, ie not things like fuel pump, they break.. :thumbsup:
have fun, remember straight back, bend the knees.
:blink:
#8 james753
james753
  • 219 posts
Posted 04 April 2008 - 11:20 PM
brill 50kg's each is ok! it would be just moving it not having to lift it out a bay, thanks for the quick replies guys!
ta
James
#9 Big_Adam
Big_Adam
  • 7,435 posts
Posted 05 April 2008 - 12:11 AM
I know they weight less then a very very fat person, having moved one using my wheelchair.
#10 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 05 April 2008 - 12:16 AM
I know its less than the Vaux engine im putting in which weighs 128.4kgs. I have managed to lift engines into the front of mine without the front end on with just two people.
#11 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 05 April 2008 - 12:25 AM
me nd my pops lifted mine out of the back of a landrover no worries.
#12 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 05 April 2008 - 05:33 AM
Fingers, toes and back. Wear Gloves, Steel Caps and keep your back straight and upright. wear old clothes too... or wrap the thing in a sheet before lifting. With correct tequnique, i can lift one in and out of the boot, to and from the floor on my own.. I have not done so for about 2 years.. i now use a hoist. it takes a lot longer but is far, far safer.
#13 ginigwunkle
ginigwunkle
  • 2,018 posts
  • Local Club: sheffield mini club
Posted 05 April 2008 - 09:14 AM
removing the oil is a good weight saver!
and mess! lol
