Best Way Of Doing A Flip Front
10 replies to this topic
#1 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 05 April 2008 - 08:57 PM
Hi all im planning on flip fronting the mini but dont want it to look like a flip front and would ideally like it to have the apanels built in
whats the best way of making and fitting it
also what type of fasteners look good if not invisible
thanks all
#2 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 05 April 2008 - 08:59 PM
have a look at my prodject, link is in my signitre
#3 mini.cooper998
mini.cooper998
  • 685 posts
Posted 05 April 2008 - 09:29 PM
looking good puddings nice way of doing it but how do i make it so that the join to the apanel is not visible
andy
#4 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
Posted 05 April 2008 - 09:33 PM
You can get flipfronts with the A-pannels attached might be a good idea for you
#5 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 05 April 2008 - 09:34 PM
Or you could deseam it
#6 mini.cooper998
mini.cooper998
  • 685 posts
Posted 05 April 2008 - 09:43 PM
deseaming would mean doing the whole car and carnt be ars@d with that (although does look good) as regards one with an apanel built in how do i hide the fasteners then and how will they apanel pas the door as it travels forward
i dont like to see a big join or gap in the apanel wing mount so want it to look as standard as possible
will probably do it in steel and figure out the mounting as i go along
has anyone done a steel flip front
#7 mighty mini jack
mighty mini jack
  • 5,095 posts
Posted 05 April 2008 - 09:52 PM
Most of the fiberglass fronts (with a panels) dont have the seam check out www.tdkracing.co.uk/www.asbmotorsport.co.uk for prices ect.. The quality from abs and tdk are very good and alignment is good aswell but with all fiberglass front you will have to do quite a bit of trimming etc.. as no mini's are exactly the same shape.
heres a pic of one with A panels: Posted Image
I know minivanman has done a steel flip front on his van, have a look on complete mini rebuild on page 3 theres some info in his thread mate or you could pm him.
Edited by mighty mini jack, 05 April 2008 - 09:57 PM.
#8 jack_marshall
jack_marshall
  • 2,540 posts
Posted 05 April 2008 - 10:48 PM
Use steel panels and turn it into a flip front that way.
If your wanting a flipfront that looks like original, you'll never be happy with a fibreglass one as they never quite look or fit right.
The price of 2 A panels, wings and a front panel isnt much more than a plastic front anyway!
#9 mini.cooper998
mini.cooper998
  • 685 posts
Posted 06 April 2008 - 08:43 AM
cheers all steel front it is i will weld brackets to the back of the wings and a panels and bolt it behind so i can still fit a complete arch (dont like wheel arches cut in the middle as they never look to line up) and can then place the metal seam trim back over.
has anyone done it like this
andy
#10 tuktuk
tuktuk
  • 1,231 posts
Posted 06 April 2008 - 09:20 AM
i have a flipfront made from steel panels, worked out just as cheap to do it steel, as it was to do it fibreglass but you get a better finish :dontgetit:
mine is held to whats left of the inner wings by little latches, they also hold the a panel and wing together :P the front is held to the subframe using 2 garden gate hinges, 5monies from homebase... works a treat.
this is where mine started to shape up flipping wise
http://www.theminifo...x...69774&st=75
#11 Trombone_Bob
Trombone_Bob
    Starting My Mini Up
  • 3 posts
  • Local Club: No
Posted 13 March 2009 - 01:38 AM
I was wondering if anybody had a picture of a flip front with the A panels attached kinda like the picture. I want to see how it would flip with the A panels. Also would you flip it up or forward
