Brake Test Switch Ignition
9 replies to this topic
#1 tlerner87
tlerner87
  • 46 posts
  • Local Club: ELMO
Posted 06 April 2008 - 01:44 AM
Reading through one of the threads in here, someone mentioned that they wired up the ignition start to the brake test switch, so that you have to hold it while it starts and then you can release it.. I think its a fantastic idea for security, in combination with other stuff of course. Noone followed it up though. Has anyone done it? How? Cheers!
#2 il-barba
il-barba
  • 839 posts
  • Local Club: malta mini
Posted 06 April 2008 - 07:27 PM
i think it could be done by a relay.
#3 Danny_California
Danny_California
  • 1,263 posts
Posted 06 April 2008 - 07:41 PM
:P You can do anything if you have a relay! lol
#4 analogue_radio
analogue_radio
  • 4,897 posts
Posted 09 April 2008 - 10:48 AM
Can this be done then, & how?
It'd be a nice security thing I wouldn't mind having.
I'm guessing you break a wire from the ignition, feed it through the brake test switch, and back to the ignition, so when it's pressed the circuit is complete and away you go?
I'm shocking at electronics by the way, so the above was a guess.
#5 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 09 April 2008 - 09:06 PM
almost 100% certain you are correct with that mate
:shifty:
#6 Ethel
  • 26,004 posts
Posted 09 April 2008 - 09:16 PM
The switch already has an ignition dependent supply.
If you just interupted the the starter motor it would be no protection against bump starting and if you interupted the ignition coil you wouldn't want to have to drive around with your finger on the brake switch.
I'm sure it can be done just needs a little more thought - oil pressure switch, crossover relay?
#7 THedooBZ
THedooBZ
  • 887 posts
Posted 12 April 2008 - 08:17 PM
had a little think about this,, on later minis 1988 onwards i belive they have a wire in the loom which is white and red,, this wire is for the automatic transmission inhibitor switch. now im not 100% but i belive by placing a switch in series with this wire would create a start switch??? i have no idea what the purpose of the switch on an automatic model is if someone has an auto maybe they could shed some light??
this then i belive would work if this is true about the wire as on later models it just has a plug and socket style join to create the connection,, thus adding a switch would make it possible to prevent the car from starting so you could hide the switch??? does anybody agree?
#8 RobJaxon
RobJaxon
  • 225 posts
  • Local Club: dont know
Posted 12 April 2008 - 09:18 PM
what do you mean???? i dont understand the 1st post
#9 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 12 April 2008 - 09:20 PM
in a similar fashion my fuel pump is wired through the fog lamp switch - good simple immopbiliser.
I have no foglights by the way b4 you ask.
#10 nurseholliday
nurseholliday
  • 690 posts
Posted 13 April 2008 - 04:56 PM
PM Lowandslow if you're that interested. He's done it.
