I need to remove the whole locking system from my mini, but not sure how to. I have unscrew the interior handle that you pull to open the door, and the little switch interior thing that locks/unlocks the door. I have also unscrewed the lock mechanism on the side of the door. What do i do next? I have unscrewed the two screws holding the exterior handle on also.
This is pretty ergent because its off to paint soon.
Door Lock Removal
d4v1dtyler
, Apr 06 2008 10:16 AM
1 reply to this topic
Posted 06 April 2008 - 10:16 AM
Posted 06 April 2008 - 10:26 AM
you need to unscrew the the latch which is the large white block inside the door shut.
when this is loose you will be able to pull it out about an inch and un-clip the actual door handle from it.
after that it should all come away
