I have been offered a delloroto carb and was wondering if I have to weld a box into the bulkhead to accomodate the carb?
If so, is there a way around this?
Thanks, Robbie
Webber/delloroto
Ro8bieg
, Apr 06 2008 09:58 PM
6 replies to this topic
Posted 06 April 2008 - 09:58 PM
Posted 06 April 2008 - 10:12 PM
You can use a "swan neck" inlet which has all the flow of a dead pidgin.
Or downdraft (through bonnet) think you need specific ones for that. Or the box, you can just use a battrie box.
Posted 06 April 2008 - 10:13 PM
When you say downdraft, does anyone have an more info on that?
Posted 06 April 2008 - 10:19 PM
down draugh IDA weber...rather rare (as oposed to the fake rear thats on e-gay) found often on VW things (not that often) so a custom manifold would be required and defence against carb icing because the manifolds are exposed to moving air past
Posted 06 April 2008 - 10:20 PM
So i wouldnt be able to have the delloroto carb slightly sticking out the bonnet??
Posted 07 April 2008 - 09:56 AM
BUMP!!! anyone?!?!
Posted 07 April 2008 - 11:46 AM
its not designed to stick through the bonnet, its designed to sit horizontally rather than vertically, so no, not really, 2-3 hours to cut and weld in a box, give a quick prime and spray and you're done, MORE POWER
less fuel in your tank though lol!
