Help
hcmini1989
, Apr 07 2008 07:18 PM
4 replies to this topic
Posted 07 April 2008 - 07:18 PM
hi there any got any pics of a choke linkage on a standard turbo carb as i dont have a clue how it goes and would i need to change the loom to fit an electronic dizzy as it running points what else would i have to change to get an electronic dizzy to work
Posted 08 April 2008 - 08:56 AM
You'll need a 12V coil and 12v supply to coil. Then its just a case of adding a couple of wires from the coil to the 2 terminals on the ignition module on the dizzy...and hey presto!
You'll find a fair few good pics of a turbo carb on TM.
EDIT: just had a though is this an A+ block?
Edited by matty..., 08 April 2008 - 08:58 AM.
Posted 08 April 2008 - 09:43 PM
alls can any one tell me were i can get some pipe to from the turbo to the ari filter or what size it is its a starard t3 turbo i thinkYou'll need a 12V coil and 12v supply to coil. Then its just a case of adding a couple of wires from the coil to the 2 terminals on the ignition module on the dizzy...and hey presto!
Posted 09 April 2008 - 09:44 PM
Avonbar sell an uncrushable pipe (need this due to high vacuum), alot of people also use silicon hose, ebay has plenty of suppliers of this, can't remember what the inlet size is though? Lol
