allegro engine??????
mini998
, May 06 2005 10:34 AM
11 replies to this topic
Posted 06 May 2005 - 10:34 AM
can i fit an Austin Alegro engine to my 1974 austin mini,without any body modifications?
is this a worth modification??
Posted 06 May 2005 - 11:11 AM
If it's an A series then yes. If it's the other Allegro engine (I think it was O series) then no. It's still a 1275 A series engine the same as from a Metro or a 1300 or any other A series, and how good it is will depend on exactly which model of Allegro you are pulling it out of.
Posted 06 May 2005 - 11:20 AM
dont know exactly which model,but i think its from 1980's and 1500cc ithink ,and it has 5 speed gear box,a non round stearing wheel, this car has been used for racing so its a very powefull engine
Posted 06 May 2005 - 11:27 AM
No you can't, sorry.
Like I said, the Allegro engine which will fit is the 1275. The 1500 is the O series version.
Posted 06 May 2005 - 12:04 PM
did the allegro not have a b-series? might be wrong. I know some people have fitted 1500 maxi engines to minis before now, they usually have a bulged bonnet because the block is longer but i would think its far from a straight swap.
Posted 06 May 2005 - 02:28 PM
Nope, defintely an "O" series, which is an OHC not OHV like the A and B
ended up in the montego and maestro.... ( says it all realy ! )
IMO, if your going to move away from an A series, go for something modern for which you're still going to be able to get bits for, like a "K" series or Vtech
Posted 06 May 2005 - 11:50 PM
errrr montego, maestro. i was thinking maxi i'm just a crazy fool!
Posted 07 May 2005 - 04:17 AM
no, you were right mate, the maxi/allegro used the "E" series..
Fek, new I should have been listeneing in english, all the vowles have got me confused now..
Simplest answer is to look here... under engines
The unofficial Austin Rover site
Posted 08 May 2005 - 08:16 PM
thats sites the best site iv found in the last year
Posted 08 May 2005 - 08:53 PM
If you move the bulkead further back you can out an E-series engine in a clubby.
Then again its not wrth it now as there is virtually no tuning parts available and fort eh hassle a K-series is much better.
Oh its a common misconception that the Allegros had B-series. O-series was a development of B-series, same (ish) block. Should have gone into the MGB (grrrrr Donald Stokes stopped that!). O-series was then devleoped into the gutles M-series for the 800, then M-series was developed into the T16-series (much better) for the R17 800. Typical BMC>MGR, recycling what they've got becasue of no money!
Posted 08 May 2005 - 11:26 PM
o-series was also fitted to the montego in 2litre efi configuration, one of the fastest mass produced road cars at one time!
Posted 09 May 2005 - 10:34 PM
You mean 2 litre Montego Turbo don't you??
Montego Turbo - the fastest T&T car in the world for £300.
