Speedo
Posted 10 April 2008 - 12:36 PM
was wondering are there any mini smiths speedos with a chrome ring which is 4 inches in diameter ? Looking for a speedo to fit in a innocenti dash. I think the mk1 speedo is to big because its 5.5 inches wide ?
any help with what speedo i can put in there ? has to have a chrome ring
thanks
Posted 10 April 2008 - 01:14 PM
Without being able to look closely at possible suspects then it is difficult to say if one will or won't fit
Posted 10 April 2008 - 01:47 PM
Linky
for example could i get the above speedo to work in a mini ? would it be accurate ? do i use a mini speedo cable ?
thanks for the advice Graeme
could i use the speedo in the link ? i dont mind about changing cables or anything because the car is undergoing a full restoration anyway. Would it be accurate ? especially with 13 inch wheels or are speedos never accurate with 13 inch wheels ?
thanks
Posted 10 April 2008 - 03:29 PM
MGB and Midget speedometers were available in 4" and 3.5" case sizes depending on the age of the vehicle with the larger gauges used in the early cars. IF you find a TPM or TPK number of 1280 or 800 respectively on your Inno speedometer, you will be able to find a similar MGB or Midget gauge. The picture in the link shows a TPM value of 1080 and I'm not familiar with any Mini speedo calibrated that way.
IF you are lucky and find that the 1280 TPM ratio is what you want, keep watching ebay and one will surely turn up. They were common on the MGBs without overdrive. When you buy the gauge you will also need to buy a new speedo cable. It is my understanding that the Inno used a different thread on the speedo end of the speedo cable. If you can't find a Mini speedo cable that will reach, contact Speedy Cables as suggested above. I'm sure they will be able to make a cable to your specifications.
Posted 10 April 2008 - 04:22 PM
Posted 16 April 2008 - 09:12 PM
but now my question is what speedo cable can i use with this ? would a mini one fit ?
thanks
Posted 16 April 2008 - 09:18 PM
Posted 16 April 2008 - 09:28 PM
are you saying i should try a mini speedo cable with it ? If that fails try speedy cables ?
thanks for the speedy reply
Posted 16 April 2008 - 10:40 PM
The most common Smiths cables (as used on early Minis, MGs and Triumphs) have an M19x1 threaded nut for the gearbox end, and an M12x1 threaded nut for the speedometer end. Once you know the length of cable you need you'll quickly know if one of the standard Mini cables will fit. If you need a non-standard cable you MAY find that something close is available for other British cars. Speedy Cables should be able to tell you if there is a cable close to the length you need and if not... they can take a longer one and shorten it for you.
Posted 16 April 2008 - 10:41 PM
