Spark Plug Gaps With Electronic Igniton
14 replies to this topic
#1 Lund
Lund
  • 1,864 posts
Posted 10 April 2008 - 03:48 PM
Hullo all,
Just a quickie >_<
I've recently changed my 850 to elctronic ignition (wow what a difference!) , my spark plugs are currently gapped according to the haynes manual. Should I widen the gaps of the sparkies a tad since there is a far healthier spark at the plugs? If so what size? Or should I not bother?
Thanks in advance,
Tom
Edited by Lund, 10 April 2008 - 03:49 PM.
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 10 April 2008 - 04:30 PM
This has been a popular topic recently paired with people who wanted to fit Sports Coils.
By all means experiment a little and open up the plug gap. Be conservative though as you don't want to make the car have driveability problems. I would say aim for about 0.030" (3/4mm) and take baby steps up from there.
#3 Mayfair85
Mayfair85
  • 268 posts
Posted 10 April 2008 - 04:33 PM
What difference do you notice with electronic ignition? Presumably you changed the coil as well? I only ask because I am considering it.
#4 Lund
Lund
  • 1,864 posts
Posted 10 April 2008 - 04:35 PM
Ok thank you, might give it a go >_<
The electronic ignition on my dizzy is designed for a standard coil. Therefore a sports coil would probably 'burn it out' or be too much for it. Acceleration is more responsive, more noticeable when dropping gears, she idles at a slow speed and only need the choke 1/4 way out to start within 3-4 mins it can be all the way in! Brilliant!
Edited by Lund, 10 April 2008 - 04:36 PM.
#5 Lund
Lund
  • 1,864 posts
Posted 10 April 2008 - 04:46 PM
Mine are currently set at 0.025" (0.625 mm)
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 10 April 2008 - 05:07 PM
Use the search features for threads that detail what's different. Succinctly, the electronic ignition systems handle switching differently than the mechanical system that opens and closes the points. This allows an optimum on/off time for the coil and therefore... allows the plug gaps to be opened up... which equates to higher spark voltages and temperatures.
#7 Lund
Lund
  • 1,864 posts
Posted 10 April 2008 - 05:43 PM
Hey Dklawson,
I think I have self adjusting plugs! My NY9's were all perfectly at 0.031 thou! Could try going larger from that, but maybe for another day, weathers got the best of me! :( Plugs were all in good condition I'm happy to say
#8 scars
scars
  • 197 posts
Posted 11 April 2008 - 12:22 PM
hi lund, which system did you buy and how much did it cost? sounds like it's done a good job, I want to get electronic ignition on my thousand.
#9 Ethel
  • 26,185 posts
Posted 11 April 2008 - 12:58 PM
Metty Turbos were specified at 40thou gap so you could take it a bit further yet.
A better spark equals faster burning so you can reduce the advance a bit.
Edited by Ethel, 11 April 2008 - 01:05 PM.
#10 flamenco
flamenco
  • 210 posts
  • Local Club: Malta Mini Owners Club
did you have to reset the timing when you fitted the electronic ignition, or just a straight swap?
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 11 April 2008 - 01:22 PM
You can generally fit the electronic ignition (specifically Ignitor) components to the dizzy and get the car started. However, you should ALWAYS check the dynamic timing and reset it as necessary.
Remember, when you put the electronic ignition components in, there is no guarantee that the switchgear will be in exactly the same position as the points were.
#12 Lund
Lund
  • 1,864 posts
Posted 12 April 2008 - 09:47 AM
Mine was simply a straight swap. I think the heat of engine caused the spark plugs to widen. Should I open them up more then? Theyre at 0.031 " now. So what should I step up to?
#13 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 April 2008 - 11:27 AM
Clean the plugs and make small gap increases, I doubt you'll find the engine runs well above a 0.035" gap. Remember that the plug gap will widen with continued use so don't over do it. If 0.035" works, open them a bit more until the engine stops running well... then close the gap up at least 0.005" and remember to check them. If gas mileage suffers, close the gap up a bit more.
#14 scars
scars
  • 197 posts
Posted 12 April 2008 - 09:17 PM
hi lund, think you missed my question above, what ignition system did you use? seems to be a few on the market, also how much was yours?
#15 Lund
Lund
  • 1,864 posts
Posted 13 April 2008 - 06:39 PM
You have a PM! :-
Opening the gaps to 0.035 right now!
