No Indicators, Brake Lights
Posted 11 April 2008 - 03:55 PM
I have noticed that I have no Indicators, either on hazard or on stalk, no brake lights, the heater for the back window does not work either.
Now i believe these will all be on the same circuit..... so i checked the fuses in the 4 type fuse box, there fine, checked the connections and renewed them all just in case, there now fine.
Then i took my airbox off, checked the inline fuses, im not sure what those fuses do... but there fine.
Im stuck for ideas, could it be a corroded wire?? if so how do i figure our which one.
Any ideas welcome, otherwise come monday i've got him booked into a garage. (friend so get discount) its just I want it over the weekend.
Thanks in advance
Kev
Posted 11 April 2008 - 04:01 PM
Posted 11 April 2008 - 04:06 PM
If everything at rear has packed up suggests that there is a problem with the part of the loom that goes to the rear of the car, check for chaffing where it goes up windscreen pillar etc. Also I may be wrong but I seem to remember that there is at least one earth in boot, that might be corroded ?
Depending on whether your Mini is of 1976-1996 vintage: -
Standard 4 fuse box mounted on the bulkhead: -
1 1-2 35amp Brake Lights, Reverse Lights, Direction Indicators & Rear Screen Demister.
2 3-4 25amp Horn, Headlamp Flasher, Brake Failure Circuit & Radio Memory.
3 5-6 25amp Heater Blower Motor, Windscreen Wipers, Washer Motor & Instruments.
4 7-8 15amp Side & Tail Lights & Panel Lights.
1-2 These circuits only operate with the ignition switch at position "II".
5-6 These circuits only operate with the ignition switch at position "I" or "II".
4 Fuse box wiring colours: -
White - Green
Brown - Purple
Light Green/White - Light Green/Orange
Red - Red/Green
I have double checked the,
And this fuse and connections are fine, they have new connections and the fuse is in place.
EDIT:
The horn is working as is the headlamp flasher along with the brake failure light. just the Hazards aren't.
Your right, the hazards are on a different circuit.
Daft question, could it be a bulb so therefore not completing the circuit?
Edited by Kinjo, 11 April 2008 - 04:08 PM.
Posted 11 April 2008 - 04:13 PM
Posted 11 April 2008 - 04:16 PM
Thanks, i have taken a look at the wirin diagram and it confuses me far to much. lol
Posted 11 April 2008 - 04:39 PM
Posted 11 April 2008 - 05:41 PM
Really wanted/needed to go out tonight and tomorrow - this is my daily driver for the next 10-11 months
Posted 11 April 2008 - 06:55 PM
but i have now noticed that side lights and rear 'lights on' don't work, any ideas?
Posted 11 April 2008 - 07:14 PM
After a trip to Halfrauds for 2 packs of glass fuses, and after I replaced all fuses for new regardless if ok or not, emery clothed all connections, and put new spade connections on, they are all working as they should do, so im a happy boy.
The quoted post above, has been one of the most helpful posts i've seen on here I think someone should pin it in a seperate post. The only thing that needs adding to it is the in line fuses, colours, etc, etc.
Thanks for everyones help, im so glad it is sorted. Gonna treat him to a wash and clay bar tomorrow, and if he is lucky i might grease his nipples
Kev
Edited by Kinjo, 11 April 2008 - 07:15 PM.
Posted 11 April 2008 - 09:38 PM
In-Line Fuses situated behind air-filter on the bulkhead: -
15amp - Purple/Orange Wire
Hazard Warning & Interior Lamps
15amp - Brown/Orange Wire
Dim-Dip Lighting
10amp - Blue/Orange Wire
Rear Fog Guard Lamps
15amp - Blue/Red Wire
Auxiliary Cooling Fan (where fitted)
