i am tryin to get a perment live to me cd player so that it keeps all the settings. i have just took a live feed from the starter solnoid.
and power supply of number 3 and 4 fuse (25 amp). but when i turn the ignition on nothin happens. and i have checked for power with a multi metre and i am getting power to the headunit. but nothin hapens.
the permeant live is only fused at the head unit with a 15 amp fuse. do i need to put another inline fuse in ? maybe
i just dont no what the problem is can anyone give me some advice please.
Radio Problems
998 mini
, Apr 12 2008 05:13 PM
7 replies to this topic
Posted 12 April 2008 - 05:13 PM
Posted 12 April 2008 - 05:25 PM
If you are taking a feed from the starter solenoid into the cabin, you should always have a inline fuse. However, not having an inline fuse wouldn't stop your radio from working.
Are you sure it is wired up correctly and has a good earth connection?
Try checking the fuse on the back of the stereo, there is a small chance that could be fried.
If the fuse is fine, and it is wired up correctly (permanent live, switched live and ground) then there is a chance the radio is dead.
Daft question, once you have turned the ignition on you have tried pressing the on button right?
Posted 12 April 2008 - 05:29 PM
yes good earth and connected up correctly
fuses ok
the radio is fine when i take the memory cable from a switched live ( but then it doesnt rember my setting)
yes i have pressed the button ( ha ha )
fuses ok
Posted 12 April 2008 - 05:39 PM
So the radio doesn't work at all when its connected properly. But if you connect both the permanent and switched lives to a switched live it works (but obviously doesn't remember your settings).
That suggests a problem with the permanent live that you have run (I think you are calling it a memory cable).
More strangely from what you are saying, when both permanent and switch are 12V, it only worked if they came from the same 12V source?
That *can't* happen, 12V is 12V, simple as that. The only thing I can think of is the cable you are running isn't powerful enough for the stereo so although it has 12V it doesn't have enough current to turn on. However, I find this highly unlikely.
Have you tried reconnecting the stereo to the switched live and testing if it still works...?
For a permanent live wouldnt you want to take a fused feed from the battery?
Posted 12 April 2008 - 05:45 PM
You could do, but as the battery is in the back of a mini its often easier to take a feed from the starter solenoid as it is connected directly to the battery. Saves more than one cable running the full length of the car from the battery.
Posted 13 April 2008 - 12:19 PM
ok now i have check for
permanent live (yes)
power supply when ignition on (yes)
earth (yes)
pressing the button to turn it on (yes)
still no joy i dont no what the problem could be ?
earth (yes)
Posted 13 April 2008 - 12:23 PM
Maybe the radio is caput. Have you tried it in another car?
