Parts List For Turbo Conversion?
8 replies to this topic
#1 Danpolk
Danpolk
    Previously known as 206boyracer
  • 220 posts
Posted 14 April 2008 - 02:47 PM
Hi guys i hope someone can help me please. I am looking to purchase a mini and replace its engine with a metro turbo lump. What i would like to know, as i am on a limited budget, is what are the minimal parts i will need. Also are there any years or models of mini which would be best to use as my base. Any other info would be greatly appreciated!! Many thanks!!
#2 Ethel
  • 26,078 posts
Posted 14 April 2008 - 02:54 PM
Best to find a scrap Metty Turbo with a serviceable engine - good luck!
the costs soon mount up if you have to buy bits here 'n there
Any post 84 mini with disc brakes will be as good as the next if you do a complete engine swap.
#3 Danpolk
Danpolk
  • 220 posts
Posted 14 April 2008 - 03:00 PM
Is it goin to be worthwhile doing then or would it be more cost effective to tune a standard mini engine?
#4 Ethel
  • 26,078 posts
Posted 14 April 2008 - 03:08 PM
Depends what you want. Turbo bits go for silly money - you could build a nice, reliable, NA lump for a fair bit less. Search Metro/mini turbo on ebay to get an idea.
#5 Danpolk
Danpolk
  • 220 posts
Posted 14 April 2008 - 03:19 PM
You dont have any idea of the parts i will need do you? Other than an engine, gearbox and custom exhaust?
#6 Ethel
  • 26,078 posts
Posted 14 April 2008 - 03:25 PM
Fuel Pump
Fuel Pressure Regulator
Carb Plenum
Carburettor
Inlet Manifold
Ex Manifold
Turbo
Wastegate Actuator
Exhaust Elbow & Down Pipe
Turbo Oil Feed & Drain Parts
A stack of hoses, pipes 'n a Air filter
#7 mike998
mike998
  • 328 posts
Posted 14 April 2008 - 03:26 PM
this has been covered so many times, search for old posts, there are tons of posts.
but briefly, you will need metro turbo engine, thicker fuel lines with return feed, fuel pressure regulator, fuel pump, bulkhead box, exhaust down pipe, new rad,
thats the minimum you need.
#8 Danpolk
Danpolk
  • 220 posts
Posted 14 April 2008 - 03:52 PM
Ok. Thanks guys!!
#9 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 14 April 2008 - 05:01 PM
Do a search on here, if you can't find what you want, have a look here, www.turbo-mini.com , this should answer all your newbie questions and more.
