Flip front clubby with super flares
Gubtash
, May 10 2005 10:32 PM
13 replies to this topic
Posted 10 May 2005 - 10:32 PM
iv made my clubman into a flip front but iv decided i wouldnt mind putting super flared arces on it, but i want to find out how im going to be able to split the arch so the bonnet will flip, any info would help or know of any companys who specialise in such body work?!
cheers
Gubtash!
cheers
Gubtash!
Posted 10 May 2005 - 10:54 PM
I'm not sure if you do split the arch, I think most people have it so the whole arch is attached to the flip front, ie. so the arch is never attached to the A-panel. Could be wrong though!
Posted 10 May 2005 - 11:01 PM
I've seen them with spilt arches, they don't generally line up to well from what i've seen, well someone on her will have a flip front with arches i'm sure give it time they'll pipe up soon.
Posted 11 May 2005 - 02:27 AM
i think rich (bluemini) did that with his clubby.... :smartass:
Al
Al
Posted 11 May 2005 - 02:53 PM
i was planning to cut my arches! other wise i think that if they werent attached to the a panel they would vibrate alot!
Posted 11 May 2005 - 02:59 PM
I'm planning to cut the arches on mine, but to help the location process.
The theory will be... put on flip front and fix arch as normal then cut arch at A panel seam. Where the cut is made a location tab will be added so that they slot back together...
This is all theory though !
Posted 11 May 2005 - 04:16 PM
i've cut arches on mine. they are cut at the seam.
Posted 11 May 2005 - 05:30 PM
guessworks idea sounds about right, that's what I was thinking by the time i got down to his post! as long as it's fitted and then cut it should easily line back up!
Posted 16 May 2005 - 07:50 AM
if you're gonna chop the arch in half to keep it fixed to the A panel and front you need to chop it in half first. if you fix it in place then cut it it'll spring out a bit and won't line up properly.
Nick.
Posted 16 May 2005 - 08:49 AM
i'm just in the process of fitting a set of miglia arches to a flip front, the plans are to fit the arch to the front without cutting it at all, and then secure it at the back(on the A panel) with a quick release fastner.
Posted 16 May 2005 - 08:55 AM
yeah thats the way i was gonna do mine.
but seeing as its only a 2nd hand front to do me until i can afford carbon i just did em like that, the arches were grp 5 euro's that i had on it when it was roundnose, just chopped em to fit the clubby front. will be changing them when i get the carbon front as i'll be going down to 10's at the same time.
Posted 16 May 2005 - 09:29 AM
so does that mean you'll be selling those wellers?? :cheese:
Posted 16 May 2005 - 10:09 AM
not sure yet...i know how hard to come by they are
Posted 16 May 2005 - 11:18 AM
ok mate fair enuf!i know i wouldn't sell em!!lol but if you have a mad moment n decide to sell em if you could give me a shout?
then it'd be very appreciated!altho not deffo to buy em!
thanx
thanx
