How Do I Drain Coolant From The Block?
5 replies to this topic
#1 ourkid
ourkid
  • 177 posts
Posted 17 April 2008 - 06:11 AM
Thanks for the advice yesterday about removing my rad - it's off now (think i need to junk my haynes manual)
Anyway,according to the book i should have a block drain plug about half way up the block at the back.However all i have is a large rectangular plate which is sealed to the block and i don't really want to disturb it.I deffinately don't have a plug.It's a 78 auto.I need to get all the water out as it's full of oil from when my head gasket went and i can't flush it with a hose because the head is off,
please help...
Ade.
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 17 April 2008 - 06:25 AM
Why not wait till you've rebuilt it then flush it through ??
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 17 April 2008 - 07:41 AM
only really early A series engines have a drain plug which would be located on the back of the block on the offside...
#4 ourkid
ourkid
  • 177 posts
Posted 17 April 2008 - 08:25 AM
Good idea >_<
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 April 2008 - 07:44 PM
If you've got the rad out, the block is drained. The water pump is pretty much at the lowest point in the water jacket, once you remove the bottom hose or the rad from the end of it there is nothing to hold the water in. As said above, once the car is re-built flush the oil and coolant. Run the car on oil and a can of oil flush for 15 minutes and then change the oil and filter again, add coolant flush to the rad and change the coolant again in a week.
#6 ourkid
ourkid
  • 177 posts
Posted 18 April 2008 - 07:13 AM
Great advice Dan - cheers!
