Head gone?????????/
Posted 11 May 2005 - 11:52 AM
is it due to bad head,and how can i tell whether head is gone or not!!!!!!!!!
Posted 11 May 2005 - 12:28 PM
Posted 11 May 2005 - 02:51 PM
Now assuming from your details, you're in slightly warmer climes that our selves, minis will run hot, have you tried an alternate thermostat, and also a smaller pulley on the water pump so the fan rotates faster, or even an additional electric fan ?
Posted 11 May 2005 - 03:24 PM
Posted 11 May 2005 - 04:04 PM
Posted 11 May 2005 - 11:15 PM
could actually be that the timing is out which can cause engine to get too hot and usually make them a pain to start.My mini is heating very quickly,and when it is hot its very hard to start the engine(which i posted in a diff thred)
Posted 11 May 2005 - 11:41 PM
Posted 12 May 2005 - 09:35 AM
Posted 12 May 2005 - 05:29 PM
Posted 12 May 2005 - 11:36 PM
Siggy
Posted 13 May 2005 - 12:00 AM
Any engine that pushes water out is a prime suspect for headgasket failure, you may or may not have water mixing with your oil, the easiest check is to remove the plugs, if you find an odd colour (usually rusty, but not always) on one or two plugs then you should suspect the gasket. The definitive tests are a combination of compression test and rad pressure, most garages can do these if you don't have the equipment yourself. Either way, changing the headgasket on a Mini is fairly straightforward, follow the Haines manual step by step & you won't end up in trouble. Max torque should be 45 Lb/ft - don't be tempted to overdo it!
Posted 13 May 2005 - 01:28 PM
