Mole Grips On Braided Brake Lines
8 replies to this topic
#1 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
  • Local Club: fabmoc/TMF
Posted 19 April 2008 - 03:02 PM
As above need to remove the caliper without loosing much fluid so was thinking of putting mole grips on the hoses while we do what we need to do?
#2 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 19 April 2008 - 03:05 PM
you can by a special clamp that will do the job, halfords ill sell it, i wouldnt put the mole grips on the pipes. ultimatly upto you though, although they are braided, i would still be afraid of damaging them
#3 Puddings
Puddings
    Nurburgring Master
  • 1,046 posts
Posted 19 April 2008 - 03:10 PM
Thanks, anyone else got a opinion
#4 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 19 April 2008 - 03:35 PM
yes, dont make any attempt to clamp a braided brake hose. I'm sure i read somewhere that their not designed to be clamped.
someone will correct me if I'm wrong but for now, to be safe, dont :bah:
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Never clamp braided PTFE hoses. The hose itself inside the braid is plastic, not rubber. It won't recover from being clamped.
#6 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 19 April 2008 - 03:37 PM
ha ha.... snap :) (that's posts, not brake hoses :bah: )
#7 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 19 April 2008 - 04:33 PM
Aye, as above, dunna do it pud!
You could always do what I do and have a load of crimped copper brake pipes in your toolbox, with a load of different ends on them (made up of broken old brake pipes etc). Pop them on the end of the hose and it won't lose as much fluid. :bah:
#8 m1n1
m1n1
  • 769 posts
  • Local Club: I'm unsociable
Posted 19 April 2008 - 05:41 PM
I changed a brake pipe yesterday on a landrover. Cling film over the reservoir filler cap did the trick wonderfully!
#9 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 19 April 2008 - 06:16 PM
Cling film under the res cap is a great idea and works but you can also use some plastic tube (B+Q do it) fit it over the end you have just undone and tape the other end somewhere that is higher up than the resevoir and it can't run out.
Neoprene , thats it, the type you get for fish tanks only bigger. :bah:
