Tramlining
4 replies to this topic
#1 woody17
woody17
  • 432 posts
  • Local Club: three valleys mini club
Posted 21 April 2008 - 10:11 PM
everytime i say to people i have 13x 8 wheels they say 'ooooo bet they tramline like a rit bugger' and i laugh,
but think to my self huh? what they on about?
so i researched tramlining and realized what it is, so i don't need lectures on that thanks.
how come i never experience it or ever feel it?
do not all wheels do it? or what? i feel im missing out!
ive got a set of decent rubbers on as well if that helps....
#2 langers2k
langers2k
  • 419 posts
Posted 21 April 2008 - 10:13 PM
Do you drive on motorways/A roads much?
Find a section where you can see the grooves from lorries on the inside lane! Its fun :D
#3 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 21 April 2008 - 10:15 PM
maybe the roads round your way arnt all that bad - In my neck of the woods all the lorries from the quarries have made some serious indentations in the road and tramlining is almosy unavoidable - in the mini, the laguna and event the new fiat 500 !
#4 mini_turbo_pete
mini_turbo_pete
  • 1,101 posts
Posted 21 April 2008 - 10:36 PM
I don't get any tramlining and i'm running 13X8 wheels as well, the normal thing that causes tramlining is too much negative camber and incorrect castor angle, a lot of people will stick 1.5 degree negative camber lower arms on and then lower the car when you lower a mini it gives more negative camber so you end up with 5 degrees negative camber....
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 April 2008 - 08:19 AM
That's basically it... with a suspension which is not set correctly even a mini on 10's will tramline.. or worse have a shopping trolley effect...
