Plug Weld Hole Size
13 replies to this topic
#1 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 22 April 2008 - 05:19 PM
Hey,
just wondering what size drill bit i should use to make the hole for plug welding ? is it 4mm ?
Is it the same size for all the plug welding ?
thanks
#2 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 22 April 2008 - 05:26 PM
No 4mm is too small you wont get enough penetration. 6mm is fairly normal or even 8mm you can tack through the hole if you need to align it as you go.
#3 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 22 April 2008 - 06:37 PM
So im safe with 6mm ?
thanks
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 April 2008 - 07:05 PM
get a hole punch, much easier than drilling
#5 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Yup, you can actually buy a combined hole punch/edge setting tool that will make this kind of repair much easier.
The one I've got punches a 6mm hole as said above.
#6 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 22 April 2008 - 07:26 PM
Whats the best one to get ? Price ?
thanks
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 22 April 2008 - 07:27 PM
Funnily enough I was looking at hole punch and jogglers today and I noticed the hole size it says it punches was smaller than I recalled being mentioned as a good size
http://www.machinema...-needle-scalers
again another 5mm punch ?
http://www.machinema...spot-weld-punch
#8 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 22 April 2008 - 07:31 PM
I've got one of these
http://www.machinema...with-hole-punch
The head swivels so you've got a joggler and a hole punch in one.
You can make a nice repair with this, ideal for door bottoms etc
#9 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 22 April 2008 - 07:34 PM
Sorry to go off topic, but whats the jogger part used for?
#10 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 22 April 2008 - 07:36 PM
But would it work when punching holes into the wings on the bonnet rail thing ? Wouldnt it crush the metal sticking up ?
#11 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 22 April 2008 - 07:40 PM
Greasy - No its no good for wings, the punch will only work on FLAT steel, ie wing seams, doors etc.
Tomf - The joggler puts a step on the edge of one side of the panel, this allows the other piece of metal to sit flush. This also means that you don't have to totally accurate with your cutting and measuring.
The punch also give a burr free cut, which is usefull when used in conjunction with the joggler
#12 In-a-mini
In-a-mini
  • 831 posts
Posted 22 April 2008 - 08:19 PM
these are great tools for some panel work but i tend to need more reach than the tool gives ie alot of the panels i weld tend to have plugs further in but when i do use the hole punch along a lip like the mini sill i punch two holes in one making it an oval. i have seen far too many panels pull apart from plugs that didnt take.
#13 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 22 April 2008 - 08:38 PM
I use a 7ml bit for plug welds, spot weld drills bits are for removing the welds not drilling holes for new ones. If you use a bit that size for doing plug welds on thin gauge metal, you'll probably burn through before you fill it.
#14 Matrix
Matrix
  • 589 posts
Posted 23 April 2008 - 08:51 AM
Much cheaper!
http://www.moss-euro...amp;SortOrder=2
and don't forget TMF+ get another 10% off >_<
Edited by Matrix, 23 April 2008 - 08:52 AM.
