***what Head?***
9 replies to this topic
#1 CraigyBoy
CraigyBoy
  • 407 posts
Posted 23 April 2008 - 10:40 PM
I have a 12G940 cylinder head that has 33.5mm inlet and 29mm exhaust valves with double valve springs and some porting work.
The valves are nearly touching, so couldnt gon any bigger and want to know hat state of tune this is.
The engine it's going onto is a 1275 A+ that had a 12G940 head with 29mm exhaust and 31mm inlet valves as standard.
If anyone anyone can help that would be appreciated.
Edited by CraigyBoy, 23 April 2008 - 10:41 PM.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 23 April 2008 - 11:02 PM
Wait, so what is it you want to know?
You know everything about the head already.
#3 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 24 April 2008 - 08:08 AM
stages are just a way of putting a head into a catagory so it can be sold to people
it has big valves, sorted...
any smothing of the ports...this is the important bit. you can have valves like dustbin lids, but if the air hasnt got a nice flow through the port, they are absolutly useless!
#4 Jammy
Jammy
  • 25,397 posts
Posted 24 April 2008 - 10:23 AM
To some companies that rank their heads on a scale of Stage 1-6 that may well be a Stage 3 or 4, other companies only have 4 stages of tuning on heads, so that would probably be a Stage 2. Ultimately stages don't mean much.
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,370 posts
  • Local Club: Amoc
Posted 26 June 2025 - 04:54 PM
Smooth ports is certainly not the best all and end all smooth is good for higher RPM.. rough is better for some cars with lower RPM AS IS MIXES THE FUEL AND AIR BETTER.
SMOOTH PORTS CAN OVER FLOW THE CYLINDER AND GIVE INCONSISTENT FUEL FLOW. Smooth more for atomised fuel through injection like mpi or spi.
more important to get the shape of the port correct for what you are using the car for to allow flow..
Very technical section of a mini this plenty to read and play with but as always loads of trains of though on this just find something you are happy and able to fiddle with..
Just enjoy the mini
#6 Shooter63
Shooter63
  • 1,065 posts
Posted 26 June 2025 - 08:04 PM
Start early this morning did we?
Shooter
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,370 posts
  • Local Club: Amoc
Posted 27 June 2025 - 04:39 AM
Two pages worth a read shooter63
https://www.reddit.c...pling_vs_rough/
https://www.google.c...mobile&ie=UTF-8
Always up earlier than you it appears....
#8 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 27 June 2025 - 05:44 AM
Not sure the OP will see this seeing as it's a 17 year old post....
#9 Shooter63
Shooter63
  • 1,065 posts
Posted 27 June 2025 - 07:39 PM
May I strongly suggest you toddle off over to the SAE website, pay your money and read real quantified info rather than relying on AI etc. Believe it or not, not everything that's posted on line is correct.
Shooter
#10 gazza82
gazza82
  • 3,018 posts
  • Local Club: TMF+
Posted 28 June 2025 - 04:09 PM
AI works by scanning websites for content and merging it ... so if the source is wrong, the AI advice is too ... it even contradicts itself!
I once asked ChatGPT for the replacement mileage of an Alfa MiTo cam belt. It's reply was along the lines of 'there isn't one as it's a timing chain' ... which is partially correct. Diesel engines are chain driven but all the petrol engines are belts ... so fir me AI is as useful as a chocolate teapot.
