Supercharging My 998!
Posted 26 April 2008 - 01:07 AM
which carb would i need to run off the supercharger the website kits say hi44 but when i research the carb it says that carb is best ran on a 1275 engine onwards???
has anyone done a 998 supercharger and was it easy to fit??
cheers
Posted 26 April 2008 - 08:45 AM
Posted 26 April 2008 - 07:37 PM
cheers
Posted 27 April 2008 - 08:28 PM
1. is it difficult to convert er into a supercharged 998
2. i been looking at the jonspeed supercharged kit i was wondering if anyone has the same kit?? or does someone have a different kit on theres??
3. what head will be best for running a supercharger as i think i need a low CR??
4. i know i will have to improve cooling and spark what will be best for this?? will i need a oil coolers??
many thanks
cheers
Guest_iansmini_*
Posted 27 April 2008 - 08:36 PM
However there is alot of people who say the vmax kit is pretty good!
You could use the 12g295 head and as for ignition, megajolt would be a pretty option so I'm told
I have been doing a bit of research myself on this as I am thinking of this route and that is what I have found so far
But I have yet to find would running an eaton m45 charger reduce reliability as mine is my daily driver!
Posted 27 April 2008 - 08:45 PM
Erm alot of people said the jonspeed kit is pretty poo! But i have no personal preference and cannot personally comment.
yea mine is my daily car drive but i think it should be reliable it run off the tenion belt not like a turbo if you get me
i was going to say after a 12g295 head the trouble is finding one then there is the other finding one in a good-ish condition haha
as for the vmax i aint had a look at that kit yet lol ill be goin to have a gander now thanks
megajolt sorry im new tot his sort of thing i know about the ignition but not the types??
cheers
Posted 27 April 2008 - 11:28 PM
To put on a bigger head from a 1275, you will need to pocket the block which requires taking the engine out and taking it apart to do it properly, and then as it's out you might as well fit a new cam etc. and it will all become very expensive. As a guide I did this with my 1275 and I have spent over £4000 and the engine is still not finished.
Posted 27 April 2008 - 11:59 PM
wont the standard 998head work with the gasket v max supply with it??
have you supercharged your engine there is someone on the forum with a 998 supercharged what did they use??
cheers
Posted 28 April 2008 - 06:44 AM
Posted 28 April 2008 - 08:24 AM
David
Posted 28 April 2008 - 08:28 AM
hif44 is the carb you want
its going to be stupidly fast, it will eat the first clutch you put it because you dont expect it to be that powerful
go to the gym aswell....
Posted 28 April 2008 - 08:38 AM
Why do you need a lathe?
David
Posted 28 April 2008 - 08:39 AM
Posted 28 April 2008 - 08:48 AM
David
Posted 28 April 2008 - 09:59 AM
Adding extra bits and power to your engine isn't exactly going to improve reliability is it?
