Hi Guys,
I know a few members have looked into the induction side of things through the rear side windows of late or even radical bodywork changes.
Just thought I'd share these with you:
[attachment=57251:Plastic_...ow_Scoop.jpg][attachment=57252:Plastic_...coop__5_.
pg]
They're vac formed bronze tint Poly Carb, clear also available.
They are a two part construction, an outer and an inner. The inner is shaped to fit around the main hoop of the cage and its possible to get two 4" flexi hoses out of the back. The picture doesn't show the inner shape too well because of the tint but we'll be doing some fibreglass and carbon versions very soon!
[attachment=57253:Plastic_...coop__2_.jpg]
The Poly Carb sheet is expensive to buy and the vac forming isn't done in house so again, costly! They'll come complete with an aluminium panel with two 4" tube stubs welded on to attach the flexi to.
Poly Carb complete units will be £300 pair
Fibreglass versions will be £200 pair (approx)
Carbon Fibre versions will be £350 pair (approx)
Cheers,
Les
Window Scoops
Custom_Minis
, Apr 26 2008 09:06 PM
No replies to this topic
