air intake
Posted 16 May 2005 - 03:12 PM
i read earlier that using some ducting pipe to the carb would help the performance. if i was to do the i'd need a air filter on the front wouldnt i? but would i need a second filter on the carb or could the ducting go straight onto the carb?
Posted 16 May 2005 - 04:29 PM
Not totally sure tho where are the experts when you need them?
Posted 16 May 2005 - 04:34 PM
But a very simple mod is, using the standard box filter ( with filter in ) remove the pressed metal thing off the end, and take a piece of ducting from the filter to the front of the car.
but you could remove the lot and pipe directly into the back of the carb... suggest you read Vizards bible.... :cheese:
Edited by GuessWorks, 16 May 2005 - 04:35 PM.
Posted 18 May 2005 - 09:07 AM
Posted 18 May 2005 - 10:09 AM
Karl.
Posted 19 May 2005 - 02:03 PM
Then you'd have warm air when it's warming up but nice cool air when you're moving!
Just a thought. Am I wrong?
Joe
Posted 19 May 2005 - 06:27 PM
you've got nowhere to fit the warm air feed.With a K&N type cone couldn't you keep the hot air duct and have a cold air feed?
Joe
Posted 20 May 2005 - 11:33 AM
Posted 21 May 2005 - 12:22 PM
