For a start the remote wire (blue one?) had come out of the ISO plug and i haven't a clue where it came out of.
Theres 5 redundant wires that have been cut about 3 inches after coming out of the ISO plug (1 grey, 1 grey/black, 2 white and an orange)
So ignoring those theres the ones coming out of the ISO plug and actually leading somewhere (2 purple, 2 green, 1 black, 1 yellow, 1 red, and there should be the blue one which goes to my amp but has pull out of the ISO plug)
They all come out of the plug then have been cut and connected to other wires that go up the bulkhead somewhere:
A couple of these go to earth (a bad earth i might add)
So At the moment i'm left with the thick wires from the amp and the aerial in the back of the headunit:
And i'm 99% sure all the amp wiring is correct (from left to right: positive, remote, negative, thick wires to the HU, then left and right speaker connections)
So basically What a mess! I have no idea where to start. At the moment if i connect everything (apart from the remote wire because i don't know where it goes) the headunit doesn't even light up to say theres power.
What should i do with this lot? I think if i can find out where the remote wire goes in the plug then i won't be far off getting it sorted - since thats the only wire that i know has come disconnected.
Help
