Basically this one : Trackday 1380
but with a stage 3 head :
STAGE 3 FAST ROAD 998-1275-SPI-MPI:
A fantastic all round road head used on engines from 998cc to 1380cc with fantastic power and torque gains proven on our dyno, it comes fully modified polished and ported using road quality valves and Steel guides. The chambers are re-shaped to enhance flow and aid squish then balanced and polished. The head is then re-surfaced to give desired compression and assembled with new valve stem oil seals, 160lb double valve springs, painted in either RED-BLUE-BLACK or BMC GREEN ready to fit. 998 uses 32.0 x 26.8mm valves and the 1275 uses 35.7 x 29.6mm valves.
I am now thinking of adding a supercharger, am i gonna have to have the engine back apart or can i still make good power using the setup i have? I have been looking at jonspeeds conversion with the de-compression plate.
It is making 81bhp at the wheels currently but it just isnt as much as i want!
Any advice please!
Edited by fishey798, 27 April 2008 - 07:42 PM.
