What Fuel Pump?
7 replies to this topic
#1 timothy
timothy
  • 97 posts
Posted 29 April 2008 - 06:12 PM
Is it neccessary to source a metro turbo fuel pump or can any high pressure pump be used such as the one from a renault 5 gt or an escort rs turbo?
#2 smith1380gt
smith1380gt
  • 85 posts
  • Local Club: Leamington Mini Massive
Posted 29 April 2008 - 07:43 PM
Why not just order a FACET universal pump? More info on your application would be good- turbo? High or low boost, etc.
#3 timothy
timothy
  • 97 posts
Posted 29 April 2008 - 07:59 PM
Going to be a turbo running about 10 psi. Wanted to know about alternatives to the metro pump cus i'm working on a budget and metro turbo parts seem to be going for silly money.
#4 Wil_h
Wil_h
  • 3,244 posts
Posted 29 April 2008 - 08:23 PM
You need a pump that will supply around 1 litre per minute and at at least 15psi.
Most injection pumps easily match and exceed this figure, so, yes, any pump off an injected car should be fine. I say 60psi should be a maximum as the pressure regulators are prone to distortion after this.
also, you need a roller vane type pump that produces a constant pressure, solid state 'clicky' type pumps produce no pressure in between clicks and will make for very jerky progress on boost.
#5 timothy
timothy
  • 97 posts
Posted 29 April 2008 - 08:40 PM
Ok, cheers Will. That's made things clearer.
#6 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 29 April 2008 - 09:13 PM
and for a very cheap alternative to the £90+ from avonbar etc i've been using an ebay one for a while now.
item numer is 270230171187
#7 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 29 April 2008 - 09:50 PM
As above, & yes the Renault 5 item is suitable.
#8 timothy
timothy
  • 97 posts
Posted 29 April 2008 - 10:19 PM
The pump on ebay looks like a good buy, if I can't a good second hand one in a breakers I'll prob go for that one.
